Technical Radiator Cap Pressure
Discussion in 'The Hokey Ass Message Board' started by bdw515, Mar 17, 2014.
  1. bdw515
    bdw515
    from Oregon
    I have a 1964 c10 with a 292, what is the cap pressure supposed to be for the factory radiator? My dad thinks it's supposed to be a 7lb system, but everything I have found says 13lbs. Can anyone help me out? Help greatly appreciated and thanks in advance!
  2. caton462
    caton462
    Are any of the parts rotten that may blow apart when too much pressure is applied? Raising the pressure raises the boiling point. Go with 7lbs if you are worried, 13 if things are in good shape. My suggestion.
  3. chopped
    chopped
    Under 10 for an older radiator. Looked at a thread on here just this AM. Like 7 to 9.
  4. Gman0046
    Gman0046
    The higher the pressure the higher the boiling point I use a 15# cap.
  5. unkledaddy
    unkledaddy
    Yeah, but you need a radiator that'll take the pressure.
  6. Model T1
    Model T1
    And a heater core to match that pressure. Many forget about the heater. Try 7# to see if it may be fine then maybe work up.
  7. Fogger
    Fogger
    I've always use a 7# Stant #11328 Lever release cap and a 160 thermostat on my old cars. No problem!
  8. bdw515
    bdw515
    from Oregon
    So I looked again today and my radiator is leaking just a little bit. I have been using a 13# cap but not sealed all the way. I ordered a new radiator should come in tomorrow or the next day. Should I use whatever cap it comes with? I forgot to ask what pressure it was.
  9. unkledaddy
    unkledaddy
    I've never bought a new one that came with a cap.
  10. bdw515
    bdw515
    from Oregon
    It didn't come with one, it has plastic tanks, is the #13 cap I currently have ok? Or should I get a lower pressure one when I swap the radiator?
  11. KJSR
    KJSR
    from Utah
    Dude, use the #13 cap.
  12. bdw515
    bdw515
    from Oregon
    I put in the new radiator, and set the 13# cap. I drove back from my uncles and the truck was barely blowing hot air, and the temp gauge was reading real low. It's like 12 miles of 2,900rpms it should be warm right? I checked everything and all looks good, motor wasn't too hot or anything, it was just fine. Does this sound ok? Or am I being paranoid?
  13. KJSR
    KJSR
    from Utah
    What thermostat is in it?
  14. The Bald One
    The Bald One
    Shaking my head......
  15. bdw515
    bdw515
    from Oregon
    Haha.
    I am not for sure what was put in it, I wanna say a 180 or 185? Maybe The Bald One remembers
