1952-59 Ford radiator cap
Discussion in 'Off Topic Hot Rods & Customs' started by bigshawn, Mar 23, 2012.
  1. bigshawn
    bigshawn
    So my new radiator came today and the instructions said to use a 7 to 16lbs cap depending on my motor. so since i still have my flathead should I still run the 7lbs cap or get a different one . and my 7lb cap off the old radiator dont fit anyway Thanks
  2. Ole don
    Ole don
    Seven pounds should be good for a flathead. Buy the modern design so you can use a catch can that will **** the overflow back.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    If you go higher pressure it raises the boiling point,you can probably use a 12-13 pound cap and be OK with the flatty if you do not have an overflow tank,the 16-19 pound caps are for use with the overflow tanks.
  4. bigshawn
    bigshawn
    Thanks I have a beer can for over flow just seemed to be what was laying around HAHA. I should be able to get one at the local auto parts store thanks again
  5. JeffB2
    JeffB2
    from Phoenix,AZ
  6. dwaynerz
    dwaynerz
    like the purty, but less filling than the beer can.
