Radiator; Easy Tech
Discussion in 'The Hokey Ass Message Board' started by old beet, Mar 3, 2004.
  1. old beet
    old beet
    Easy way to check an old radiator for leaks. Cut a bicycle inter tube apart, away from the valve stem, hose clamp each end to outlets, fill with water, then air up the tube. Remember to put the cap on. Leaks show up fast.Flatheads, block two off!.......OLDBEET
  2. Nocero
    Nocero
    Thanks great idea!! that is one of the simplest and best tech posts I've seen.
  3. Impala53
    Impala53
    Why didn't I think of that? Thanks! First name Albert?
  4. That's absolutely brilliant......
  5. k-member
    k-member
    Damn Dad, I just had to do that to Noa's rad. You must be a mind reader and you do look like Einstein....
  6. <font color="red"> WOW I never thought of that.....you always have the coolest Id's OldBeet.thanks
    R E D M E A T </font>
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    great idea ! This place and the people amaze me! thanks
  8. johnnygringo
    johnnygringo
    from Nashville
    got an old one yesterday and was trying to think of a good way to test it...killer idea
  9. MBL
    MBL
    That is a killer idea. One thing did come to mind though....is it possible that a rad would develope leaks at a higher pressure than what you can push with the innertube? Just a thought...I will definately try this one.
    Thanks!
    Tim
    MBL
  10. burndup
    burndup
    from Norco, CA
    Option #2... Find a car in the junkyard with the radiator still full of coolant... have fun making a shit mess when ya remove it!
  11. atch
    atch
    mbl,
    i don't know how high the pressures are in new stuff, but the older stuff we mess with only has slight pressure in the radiator. even a high tech street rod with an aluminum radiator probably doesn't go over 14 pounds of pressure (NOTE - this is where someone who knows more than me interupts with the truth) and you can put that much on a bicycle inner tube easily.
  12. Dirk35
    Dirk35
    [ QUOTE ]
    [/ QUOTE ]
    This isnt meant to sound rude.
    Perhaps someone can remember and clarify for me, but........
    We covered this in one ot the lost tech's about two years ago. I think the concensus was that a normal radiator cap is designed to blow at around 15lbs anyway, and you can air most bicycle tubes up to about 45lbs, therefore, its works fine for testing leaks at normal pressures.
    Someone please correct me if Im wrong here.
  13. MBL
    MBL
    Very good points. I was just wondering.
    Tim
    MBL
  14. Jkustom
    Jkustom
    Thats not hard enough, and not very high tech beetle, better come up with another one.... [​IMG]
  15. titus
    titus
    option 3 rubber plumbing caps, they make em in all different sizes, but they cost money.
    you can get all sorts of different rad caps also, they make 7, 11, 13, 16 lbs caps that ive seen
  16. williebill
    williebill
    Ummmm...don't want to be a jerk,but a bicycle inner tube,outside of a tire,won't hold shit for pressure.The tire contains it within the confines of the tire,the tube itself has no real strength.Take an old tube,say a 20" one,lay it on the ground,and put some air in with a small hand pump.When it expands to about 4' in diameter,it won't have hardly any air pressure in it,but it will balloon up and blow up in your face.
    But if you wrap the tube in some duct tape,being careful to cover it all,it will remain flexible enough,but hold its shape/pressure while you do the radiator test.
  17. Mr 42
    Mr 42
    from Sweden
    The Bicycle tube will work great, you need almost no pressure at all, especially íf the radiator has big tanks.
    Listen for the leak, and or use soapwater to find it.
