1952-59 Ford radiator fan
Discussion in 'Off Topic Hot Rods & Customs' started by bigshawn, Sep 21, 2010.
  1. bigshawn
    bigshawn
    is there a fan with more blades I can swich to instrad of my stock one I have a 52 flathead is there something that bolts right in or am I in for some modifications
  2. Retro Jim
    Retro Jim
    If you are having a cooling issue , try a fan shroud . They help a lot . If not use an electric fan with a manual switch so you can switch on as needed . I really don't think there is a better fan for it that will fit .
    Just a thought .
    Jim
  3. bigshawn
    bigshawn
    yea cooling issues.. what shroud did you use and where did you get it and those electric fans are expensive for cheap plastic and I still run 6 volt
  4. raceron1120
    raceron1120
  5. Retro Jim
    Retro Jim
    Well you could get those universal chrome ones you can get in any place that sells street rod parts , Summit , Jegs and so on .
    As for a fan i would get a used one from the salvage yard and keep a small 12v battery someplace in the car and just use when needed . Just charge up as needed too .
    Jim
