Hot Rods radiator for 26 roadster on A frame
Discussion in 'The Hokey Ass Message Board' started by rfrontenac, Sep 15, 2010.
  1. rfrontenac
    rfrontenac
    Hey all, Iam putting a T roadster body on a model A frame. The frame has the stock crossmember in the stock location.I want to run my high T shell in the same location but a T or A radiator wont work. any suggestions?I would beleive this has been done many times.Thanks for any input. Paul
  2. -Brent-
    -Brent-
    I'm doing something similar. I plan on shortening my radiator when I get to that stage.
  3. BBobb
    BBobb
    Look into a 65-69 mustang.I ran a 3 core on my 29 model a....good luck
  4. HomemadeHardtop57
    HomemadeHardtop57
    what bobb said..or falcon if you need the water outlet on the other side
    $115 on the shelf at auto zone or advance
  5. rfrontenac
    rfrontenac
    Thanks for the input.I think I didnt make my problem clear enough.Iam running an A engine in an A frame with the stock crossmember in the stock location.I want to put a T shell in the A location with a radiator that fits in the T shell and clears the crossmember.T radiators have too large of a lower tank to fit into the crossmember.Model A radiators are too narrow for a T shell.Dose any one make a radiator for this application or dose anybody know a modification. Thanks again my fellow car nuts,Paul
  6. -Brent-
    -Brent-
    Model A radiators are not too narrow for a T shell. If anything they're a tad too wide. I'm running a 28/29 radiator inside a 1920 grill shell. It needs to be shortened to fit but it also needed a tab cut off either side and then the shell fit super snug all the way around.
    Now, with my 26/27 T Roadster that's going to be on an A frame I'll be running a T shell and an A radiator. The A radiator is taller. I'll have to compare them to se if any other issues will pop up. I haven't done so because I'm still collecting parts for that project.
  7. rfrontenac
    rfrontenac
    hey brent thanks for your responce.I only have a 30 31 radiator here and its too narrow maybe the 28 29s are wider.btw your car is nice Paul thanks
  8. -Brent-
    -Brent-
    Are you referring to the thickness of the radiator or the width, i.e., from driver's side to p***enger's side?
    Thanks for the compliment, too.
    Also, there are dimensions for the Mustang radiator somewhere on the HAMB, which is a viable option (as has been mentioned).
  9. -Brent-
    -Brent-
    Here's a link to Mustang radiator thread with dimensions.
  10. rfrontenac
    rfrontenac
    Yes,the width. Inside to inside the shell opening is 18 and3/4 and the total radiator width is 18 I know it is not that much but it kind of looks funky to me. Do you have diferent dymentions than me? Thanks
