Radiator hose compression fittings?
Discussion in 'The Hokey Ass Message Board' started by CalrewireMatt, Oct 29, 2008.
  1. CalrewireMatt
    CalrewireMatt
    I worked on a chevy a few years back that had what looked to be compression fittings on the radiator hoses and was wondering if anyone would happen to know where I could find some. They didnt have a hose clamp or anything like that just a big hex nut holding it on(not AN hose). They looked pretty trick but I cant seem to find anything. Possibly Im just calling it the wrong thing when I google it but Id really like to get my hands on a few.
  2. thall
    thall
    from nc
    could have been a sleeve hiding the clamp underneath...
  3. sawzall
    sawzall
    i've seen something that looked like "shrink" tube attaching the rad to the hose, is this what your referring to?? because if it is, I'd sure like to know where to get it too..
  4. Paul2748
    Paul2748
    The shrink tube type of hose clamp should be available through NAPA or any of the other parts stores.
    I believe they were oem on some GM's.
  5. sawzall
    sawzall
    really??
    cool
    I'll check it out..
    thanks
  6. lurker mick
    lurker mick
    Most NAPA parts stores carry the shrink tube type hose clamps, can't help with the "NUT" style.
    Mick
  7. lurker mick
    lurker mick
    Gotta learn to type faster!!
    Mick
  8. Lotek_Racing
    Lotek_Racing
    The nut is usually just a nut shaped cover that clips on over a standard worm-gear hose clamp.
    Ususally you find these on braided covers for mullet-machine cars.
    Looks like this: [​IMG]
    Should be available at any parts store.
    Shawn
  9. CalrewireMatt
    CalrewireMatt
    nah it wasnt the gates shrink tube clamp or a beauty cover. It looked like the beauty cover but it was an actual fitting. Looks like an industrial plumbing fitting and was stainless steel. I for the life of me cant figure out what the hell its called though.
  10. scottrich411
    scottrich411
    aeroquip makes hoses with ends that you can put on or remove that use a compression fitting or somethin really similar, but thats to attach the end to the hose, i'm not sure how many options they offer for the other end. maybe it's something like that.
  11. xtralow
    xtralow
    Sawzall,
    heres a link and also a zipcode search to find someone in your area that can get you the Powergrip Clamps, you will need a heat gun to apply these clamps fyi
    http://www.gates.com/brochure.cfm?brochure=927&location_id=1177
    xtra
  12. CalrewireMatt
    CalrewireMatt
    do you happen to know the name of the fittings from Aeroquip?
  13. xtralow
    xtralow
    Are they like a T Bolt style clamp, like this?
  14. CalrewireMatt
    CalrewireMatt
    nope not a t-bolt clamp or any other hose clamp. It looked like the spectre fitting but it screwed together on to the radiator neck and clamped in down like a compression fitting. I want to say it looks like a fitting the water company would use on a water main. I wish I woulda asked the guy where he came up with it and being that he was a contracter Im fairly confident it was used in the construction industry. I just remember it because I had never seen anything like it and was rather unique.
  15. hotroddon
    hotroddon
    what you are looking for is made by a company called Pi-Thon design in Newbury Park, Ca:D Yeah
    but I think they went out of business :eek: Boo
  16. BigChief
    BigChief
    You mean Swageloc fittings? They do make huge ones, I've got a couple of 2 inchers at work we keep around as paperweights. They're so big they almost look like novelty items compared to the little ones used on instrumentation and small diameter tubing. I can't imagine anybody going through the trouble of retrofitting a radiator to use them....way, WAY expensive.
    -Bigchief.
  17. CalrewireMatt
    CalrewireMatt
    yep the pithon things are pretty much what I was talking about however the one this guy had was a hex nut style but same concept. Anyone know of the industrial name for that?
  18. hotroddon
    hotroddon
    Pi Thon offered them in both the Spanner style and Hex Nut
  19. CalrewireMatt
    CalrewireMatt
    ahh I see. well then I guess that idea is ****ed lol.
  20. CalrewireMatt
    CalrewireMatt
  21. hotroddon
    hotroddon
    I might actually have some of them left over. PM me with the hose size you need and I'll look.
