Technical Radiator hose question
Discussion in 'The Hokey Ass Message Board' started by RUSS BUCKLIN, Aug 26, 2020.
  1. RUSS BUCKLIN
    RUSS BUCKLIN
    from Seattle
    Question:
    I'm installing a 350 crate and keeping the original radiator, re-cored. The radiator guy called and pointed out that the connections on the radiator and the connections on the SBC are usually two different sizes. Anyone have experience with this? Can I get radiator hoses with different sizes on either end? I would like to keep the original radiator if possible but changing the hose connections along with re-coring it would make the cost astronomical to the point I might be better off with an aftermarket unit with original appearance. What do you guys think/know?
  2. Inked Monkey
    Inked Monkey
    I've always just stretched the hose over the different size outlet. Or cut a piece of appropriate size radiator hose and use it as a spacer to the bigger size.
    Desoto291Hemi and olscrounger like this.
  3. 51504bat
    51504bat
    When I put the 8ba in my '39 p/u the upper radiator hose on the radiator was larger than the thermostat housing. Flex hoses with 2 different diameters are available as are inserts to make up the difference in diameters BUT they were pricey. Others with the same situation use an old bicycle inner tube to wrap the smaller inlet for the larger hose diameter.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Thousands of different radiator hoses with different sizes on ether end, make friends with someone at the parts house and look at all the hoses that are shaped right our could be cut to the right size and start measuring. HRP
  5. vtx1800
    vtx1800
    Make up a "model" out of plastic pipe for shape and size and take it to the parts house and go through their inventory, in most instances they would rather stand by the cash register than help you dig through inventory:) If you noted what the vehicle was and possibly a picture some one may have had the same issue and solved it:)
    clem likes this.
  6. Casual 6
    Casual 6
    from Great NW
    There are many sizes of these hose reducers. Easier to use than trying to find the correct hose with two size ends.
  7. egads
    egads
    Google radiator hose reducer, lots of them. $8 to $10 a piece.
  8. squirrel
    Normal older Chevy V8 hose sizes are 1-1/2" for the top, and 1-3/4 for the bottom. There are many molded hoses that have different sizes on the ends, and also there are universal corrugated rubber flex hoses that have different sizes on the ends. I find that o'reilly auto parts web page is useful for looking them up, you can select end sizes and see what pops up.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I learned from a old timer years ago to buy a couple of VW collapsible aluminum heater box hoses and use them to mimic the shape of the rubber hoses needed for the top and bottom of the radiator, being aluminum and collapsible they will hold their shape and are great for reference when standing a**** the hundreds of hoses usually hanging on the wall at the parts house.
    They easily collapse and can be stored in the box for the next time you need a specialty hose. HRP
  10. evintho
    evintho
  11. Bandit Billy
    Bandit Billy
    I have had both radiators for the current builds built to match my ins and outs on the motor. I mean as long as you're at it, do it right?
    Hnstray, 62SY4 and mcsfabrication like this.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Whats not " right" about using an adapter ?
    Desoto291Hemi and VANDENPLAS like this.
  13. Beanscoot
    Beanscoot
    "Right" is debatable, but it is less likely to have leaks with fewer connections.
    VANDENPLAS and Hnstray like this.
  14. Mr48chev
    It always helps if you tell us what year and model of car we are working on so we don't have to do wild *** guessing. In this case I think it is 49/52 Chevy car and the simple but ugly way is flex hose with different size ends. My 48 had (and still has) one of those two size flex hoses on it with the 250 and a stock radiator .
    The cleaner way is to do as Hrp suggested, and find a hose the right size for the engine - 1-1/2 ID that has the right shape to reach the radiator inlet (cut to fit deal) and get one of the sleeves that Casual Six showed. Those even come in the box with some late model fit more models radiators now. Had one come in the box with the radiator I put in the 2K Cad Deville I had.
    Remember that that radiator is low pressure - 4 or so pound cap and you have to leave plenty of room in the tank for expansion.
  15. RUSS BUCKLIN
    RUSS BUCKLIN
    from Seattle
    ****! You're right, of course. I thought I mentioned, 1950 Fleetline Deluxe. Talked with my radiator guy this morning and he has adapters that he will include with the re-core. In the meantime I will go looking for variable end size hoses. Thanks for all the comments, very helpful and educational and I appreciate it.
  16. David Gersic
    David Gersic
    from DeKalb, IL
    If you’re building a custom radiator, why would you intentionally use an adapter to make it fit?
    Bandit Billy likes this.
  17. RUSS BUCKLIN
    RUSS BUCKLIN
    from Seattle
    Is re-coring my original the same as building a custom radiator? It is a fair bit more expensive to have him remove the ******s, cut new holes and braze new ******s on and the cost is already going to be high. From the comments here I am pretty certain I'll be able to find hoses that fit. If not, the adapters will be fine.
  18. Re coring your original radiator is better then getting a cheap or even a good aluminum radiator in my book. If it has a large flat sided top tank you might have to keep the pressure down. Go to the Gates or Goodyear website and download or view their illustrated catalog, find the length, curvature, hose end sizes you need and then type that number into google if you need a picture of the real part.
    flatford39 likes this.
  19. Bandit Billy
    Bandit Billy
    This is what I was getting at in my earlier post. On my blown flathead I gave Br***works the diameter and the spacing of the inlets and outlets so they were all in the right place for easy hose connections without adapters and jogging all about. Same on the Hemi. As long as you are building the radiator why plan on using adapters? That is like designing a house and putting the outlet on one wall even though the TV is going on the other wall but figuring I could use an extension cord and be fine.
    Just Gary and David Gersic like this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    That's real close to winning first prize for the most convoluted ****ogy I've ever read LOL:confused:
  21. 24riverview
    24riverview
    I put a Walker radiator in a customers 50 Chevy a few years back and used a Dayco 70885 on top, 1 1/2 both ends. On the bottom I used a Dayco 71598, 1 3/4 on one end, 1 13/16 on the other, sorry don't know which was which. There's a few variations in bottom size depending on which water pump is used. I'd ***ume the Walker probably has bigger outlets than the original.
  22. Mr48chev
    Have you actually checked on having a radiator recored in the last ten years? There is only one shop within 50 miles that will even do it and then it is more than what most high quality radiators cost new outside of the super high priced Walkers.
    The local shop that is the last one in this area to recore radiators doesn't want to deal with car or pickup radiators as they are overly busy with truck and heavy equipment radiators. They will modify one for a hot rod if you get hold of the right person and pay a premium at that.
    VANDENPLAS and 2OLD2FAST like this.
  23. Chrome Moly Steel
    Chrome Moly Steel
    from Miami, fl
    Dayco has a good online catalog with pictures. I’ve found buying Dayco hose from Rock Auto to be economical enough to purchase several of the closest shaped hose needed.
    dana barlow likes this.
  24. Yes, had the Studebaker re cored about 4yrs ago and it was about $375. The close radiator shop closed down, but I found another one about 30 min away.....I'll ask them about prices when I pick up my '41 radiator.
    All that aside I still stand by my original quote.
  25. 51504bat
    51504bat
    FYI: A little father than 30 minutes from south county especially with SoCal traffic but Fontana radiator is still a full service radiator shop. They just put a new core in the heater for my '54 Ranch Wagon and they have repaired and changed outlets on several flathead radiators for me in the past. Good guys to deal with.
    Desoto291Hemi likes this.
  26. RUSS BUCKLIN
    RUSS BUCKLIN
    from Seattle
    Here in my area there is a shop called Greenwood Radiator that does excellent work and is handling the rebuild of mine. I know it would have been cheaper to buy aftermarket, but this is the original piece for the car and that matters a little bit. I'm not sure why given all the other changes... :-/. The car is going to be driven pretty low stress and if it turns out to be a problem I can change the hose connectors later.
