Hot Rods Radiator hose ?
Discussion in 'The Hokey Ass Message Board' started by Bikelessbill, Apr 27, 2025.
  1. Bikelessbill
    Bikelessbill
    Any suggestions on lower radiator hose? SBC to alloyworks 32 Ford radiator. Have tried 10 different molded hoses and no luck yet. Haven't gone to flex hose yet but may have to.
  2. oldsmobum
    oldsmobum
    from SoCal
    The last time I dealt with this, I bent up a wire hanger to mock up the shape that I would need to get from the water pump/water neck to the radiator. Then, I went to O’Reilly’s and after convincing them that they could not find it via year/make/model they let me go in the back and prod around. I bought two or three, and used about 2/3 the best one. You’re just looking for something that seems to have a viable section in it if nothing else. I had a notepad with the part number I used for future reference.
    partssaloon likes this.
  3. Just Gary
    Just Gary
    ***uming the bottom radiator connection is on the p*** side;
    Gates #20242 or 20225, depending on how close your water pump is to your radiator.
  4. This is the best method, as long as you can find a place that will let you rummage through their hose collection. If you find a couple of bends that suit, you can always join them with a piece of copper or br*** tube of the right diameter.
  5. lothiandon1940
    lothiandon1940
    Instead of using wire, use that flexible aluminum tubing that some manufacturers use to tap heat off the exhaust manifold and direct it into the air cleaner. As used on some '70's Corvettes and others. It's a lot easier to approximate the shape than a piece of wire.
    Just Gary, ffr1222k and mad mikey like this.
  6. lothiandon1940
    lothiandon1940
    Think they call it a heat riser tube.
    Just Gary likes this.
  7. swade41
    swade41
    from Buffalo,NY
    You can also use 2 different hoses with a splicer in the middle if need be or even a section of tubing will work.
    vtx1800, 2OLD2FAST and lothiandon1940 like this.
  8. Bugguts
    Bugguts
    I just googled this last week.
    Hose for SBC to 32 style rad.
    The consensus was a lower hose for a 57 Chevy.
    Called local NAPA and had it that afternoon.
    Fits perfect with a small sliver removed.
    vtx1800, lothiandon1940 and Just Gary like this.
