Technical Radiator ID help
Discussion in 'Traditional Hot Rods' started by coonpiss, Dec 20, 2014.
  1. coonpiss
    coonpiss
    from NW Indiana
    Gentlemen, need some help figuring out what models and year radiators I have here. Thanks
  2. One is a model T ford.
  3. gwhite
    gwhite
    SUPER MODERATOR
    I do not believe any of those are T radiators...dimensions would be helpful...
  4. Racer29
    Racer29
    Top one looks like an early 40's chevy.
  5. Yeah, I'll have to retract that. Wrong upper support mount, wrong filler neck, wrong inlet and outlet, but other than that, it's close.
  6. O.K. How about '28-'29 model A then?
  7. The37Kid
    The37Kid
    When you enlarge the photos the shapes change. I think this one is an aftermarket 1928-29 Ford. Bob [​IMG]
  8. Absolutely!
  9. coonpiss
    coonpiss
    from NW Indiana
    I'll get some measurements tomorrow. Just using the one for mock up right now. It fits perfect in my cross member and i found both of them on the cheap.
  10. BJR
    BJR
    None of them have a crank hole in the core. This could help identify them.
  11. gwhite
    gwhite
    SUPER MODERATOR
    Neither do Model T or Model A radiators....
    Radiator with the 'zig zag' ribs appears to be a replacement 28-29 radiator. Not sure about the other.
  12. Carter
    Carter
    I agree with Bob and Gary on the second one being an early replacement radiator to fit 28/9 model A. Some manufacturers of those replacement radiators soldered little date code tags on them, look to see if there is anything like that on there.
  13. Binger
    Binger
    from wyoming
    The Honeycomb one looks like an early '30s chevy. I will have to go and get a better look at the one on my '30 to get a better idea. It might be a little earlier than a '30 though.
  14. carmuts
    carmuts
    The one without the bracket looks to be 23-28 Chevrolet, but I could be wrong. Rod
  15. coonpiss
    coonpiss
    from NW Indiana
    The model a measures 19 1/2 wide by 26 1/2 tall from floor to top of neck. That is a 28-29 right?
  16. Carter
    Carter
    I don't have measurements handy, but I'd bet dollars to doughnuts it's a 28/9 model A radiator.
