Radiator, is it fixable?
Discussion in 'The Hokey Ass Message Board' started by 52hotrod, Apr 18, 2012.
  1. 52hotrod
    52hotrod
  2. 52hotrod
    52hotrod
    It's off of the '41 sedan. The fan came off the water pump and made this nice gash. New radiators are $400-$500. Hoping i can get it repaired for much less.
  3. tfeverfred
    tfeverfred
    Looks fixable.
  4. Looks like a new tank and your good to go.
    What did the rad shop say?
  5. 52hotrod
    52hotrod
    Thanks, there is a local shop that is suppose to be cl***ic car friendly but i figured i would check here before i brought it in.
  6. squirrel
    Looks like a modern core, not the original, so it's likely it could be fixed.
  7. 52hotrod
    52hotrod
    I looked for a replacement at the Portland Swap Meet but all i found was a totally rusted out original. My new water pump with pulley is on back order so i guess i have plenty of time.
  8. 52hotrod
    52hotrod
    Grandpa in the '41
  9. its fixable,but might cost the same price.
  10. Soviet
    Soviet
    There might be some truth to this.
    I have had a variety of experience with radiator shops charging from very reasonable rates to an arm and a leg. Hope your shop is more of the former, and less of the latter!
  11. tommy
    tommy
    The price for cores has gone nuts in the last few years. I had the same problem and had to pay 550 bucks to get a 34 Ford radiator recored. I had a hell of a time finding a radiator shop that could or would recore it. I found a new one cheaper but due to the thicker core, I couldn't use it without major alterations. I just closed my eyes turned my head to the left and coughed.
  12. Jimv
    Jimv
    Anything man made is fixable!
    JimV
  13. Why fix it ..There are a number of companies making iexpensive aluminum ones..My son just bought a new aluminum fully welded one for his 50 Dodge on E-bay for only 135.00!!
  14. JimSwann
    JimSwann
    I went through a similiar deal with my 35 Ford Radiator. I took it to a radiator shop here in Nashville and they claimed it was not repairable but quoted me $900.00 to $1,200 for a new one, I p***ed. I called Br***works and ordered a 4 core OG style for $620.00, took 4 weeks. Its a very nice looking heavy product but I havn't installed it yet.
  15. Dale Fairfax
    Dale Fairfax
    It appears that the real damage is to the bottom header and tank and not the core. If that's the case, a competent shop should be able to remove the bottom tank, repair the header and the tank and re***emble it. In the "good old days" that would be routine.
  16. badshifter
    badshifter
    I'd rather support a local radiator shop then a cheap offshore knock-off company.
    Try getting it fixed!
  17. I wish you lived in my neighborhood....but in the real world.............when the labor cost is more than the item is worth its like force feeding a dead race horse....
  18. 52hotrod
    52hotrod
  19. 52hotrod
    52hotrod
    Made it to gas station and back with no temperature issues.
  20. 52hotrod
    52hotrod
  21. Jalopy Joker
    Jalopy Joker
    oh no, it is not show perfect - no plastic trophies for you - Ha! good that you found a place to repair it.
