1952-59 Ford Radiator Location/Clearance
Discussion in 'Off Topic Hot Rods & Customs' started by 50sboy, Jul 15, 2019.
  1. 50sboy
    50sboy
    Anyone move the radiator to the front of the U-shaped support? Extra 1" clearance - just don't know if any problem with the hood...and don't have it on to check....
  2. I did, no problems with hood clearance but it will depend on how tall the radiator itself is. I would measure mine for you but my car is half dis***embled. It sticks out above 2-3" at least though.
  3. 50sboy
    50sboy
    Perfect, thanks. Aluminum - but built to replicate the stock one so should be fine. Thanks for your help!
  4. HOTRODPRIMER
    HOTRODPRIMER
    The Ranch Wagon was originally powered with the Ivory six so when I installed the 302 I needed a little more room to be able to use the 17" steel mechanical fan, I turned the radiator cradle around and mounted the Walker radiator the few inches forward that the modification allowed. HRP
  5. 50sboy
    50sboy
    that's it - Thanks! Nice work by the way...wagon is looking good! Mine is a 56 Ranch.
