radiator puke resivour
Discussion in 'The Hokey Ass Message Board' started by jan bogert, Sep 2, 2013.
  1. jan bogert
    jan bogert
    does it matter where u mount the over flow res.? the only room I have is on the firewall. is that alright for a rad. overflow? and will it work pull antifreeze when needed ect:ect:
  2. Jalopy Joker
    Jalopy Joker
    yep, can work as long as it is lower than the upper tank of radiator.
  3. jan bogert
    jan bogert
    thanks joker. I didn't know because of being that distance away.
  4. stimpy
    stimpy
    mounted there on a bunch of semis and work trucks ( not the surge tank types either ) , doesn't matter on height as the radiator when it needs it will va*** the a/f in
  5. milner142790
    milner142790
    The top of my pile jar is about level with the rad cap, maybe just a little lower and it has solved ALL of my overheating problems.. I also was worried about the distance the pick up/ kick out line would have to be and it's functionality that way but I had to give it a shot as I only had that one spot and it has done wonders!!
