Technical Radiator recovery- overflow tank size
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 5, 2019.
  1. Blue One
    Blue One
    from Alberta
    Is there a minimum or a maximum size for one of these tanks?
    In researching them I see they’re available in a lot of different sizes.
  2. squirrel
    There is for drag racing 16 oz
  3. Blue One
    Blue One
    from Alberta
    What about just in general, not for racing.
  4. Tim
    Tim
    from KCMO
    16 oz sounds about right to me as well
  5. squirrel
    Might depend on the size of the cooling system and how hot you expect it to get and how much room you have? Between a pint and a gallon, is the perfect size.
  6. harpo1313
    harpo1313
    from wareham,ma
    find a cool little bottle and strap it on.
    scrap metal 48 and Blue One like this.
  7. Fat47
    Fat47
    The advantage of using a Pabst Blue Ribbon can is that you get to drink the contents. I have lots of empty PBR coolant cans if you need one.
    Just Gary, Blue One and squirrel like this.
  8. squirrel
    I put Schlitz on my Chevy II, but Almost Funny has a old steel tall PBR can.
    Blue One and Truckdoctor Andy like this.
  9. Roger O'Dell
    Roger O'Dell
    Fill the radiator to the top of tank , with everything cold. Get the engine as hot as you dare, capture and measure the over flow. Have expansion tank four times the measured amount, or more.
    loudbang and firstinsteele like this.
  10. rusty rocket
    rusty rocket
    Put a real recovery tank on, your T is way to classy for a god damn beer can!
    loudbang, Tim, Blue One and 2 others like this.
  11. 26hotrod
    26hotrod
    from landis n c
    I use a MOON water recovery tank and it works real good. A little pricy but it works. I mounted it in front of the grille as you would a fuel tank...…...
  12. Atwater Mike
    Atwater Mike
    Oh yeah... A nice shiny billet one. You can pick one up at a Goodguise event.
  13. Atwater Mike
    Atwater Mike
    A bud that passed away in '87 used a Moon tank on the front of his '55 Chevy 'street freak'...but it contained 2 gallons of Rhine wine, which he made available to anyone with a cup! Really miss ol' "Nooner"... But a drier white would have been much nicer!
    loudbang and scrap metal 48 like this.
  14. GordonC
    GordonC
    Just pulled this from the recycle bin to make one for my flathead. Not sure of size? 20190226_174012.jpg
    GearHeadDiver and loudbang like this.
  15. rusty rocket
    rusty rocket
    At least you could doll it up and not look like a rat rod!
  16. Johnboy34
    Johnboy34
    from Seattle,Wa
    A long the creativity of the fan shroud, I'm sure when you come up with a size it will fit the build just right. 16 to 24 ounces, do you want just a catch tank or a closed system that will suck water back in the radiator?
    Sent from my SM-G900V using The H.A.M.B. mobile app
  17. Blue One
    Blue One
    from Alberta
    I’ve been looking at some available tanks and I have figured out that I can go with a 2”x10” tank (round) and make it fit nicely.
    Such limited space for anything larger.
    That amounts to 17.5 ounces so it should work out.
    I’m leaning towards having it black like everything else.
    And yes it will serve as a recovery tank as well.
    You beer can guys and billet shiny guys are nuts :D
    Blues4U, loudbang and Tim like this.
  18. mgtstumpy
    mgtstumpy
    The general rule of thumb for proper capacity of expansion is:-
    • 12% of total coolant volume for draw down; and
    • 6% of the total volume for thermal expansion.
    Drawdown capacity is the amount of coolant that can be lost before air reaches the water pump and is introduced into the system. Air bubbles in the coolant system can cause inconsistent cooling and can also prevent the thermostat from opening if an air bubble gets trapped underneath it.
    Thermal expansion occurs as coolant accumulates heat from the engine. The 6% of the expansion volume is calculated from the amount that the coolant level will rise at 212 degrees F. This takes into account the density change of the coolant itself and all the components that are in the coolant system. If the volume is calculated incorrectly and an inadequate expansion space is provided coolant will be discharged from the system at operating temperature. To prevent the possibility of spilling coolant a catch tank or a recovery tank can be used.
    http://blog.cantonracingproducts.com/blog/calculating-expansion-tank-size-requirements
    hot-rod 33, Just Gary and loudbang like this.
  19. Mr48chev
    I did the beer can thing years ago when you had to have a puke can to run at the drags. Wasn't trying to be cute at the time, just cheap.
    I have an Ebay shiny aluminum tank out in the garage for the 48 but it may be inner fender black when it ends up in the truck.
    Those aluminum water bottles like GordenC showed are laying around everywhere and you can find them for pocket change at the thrift stores. Two holes drilled in the cap and a couple pieces of left over brake line and you are in business. 1 to the hose from the radiator and one with a 180 in it that runs back down so it vents low enough. That one doesn't want to go deep in the tank though.
  20. squirrel
    Also you can use a metal tube that runs from the radiator, into the opening of something like a beer can or water botttle, and have it almost reach the bottom of the can, and it acts like a recovery tank, not just a catch can.
    Blues4U likes this.
  21. woodhawg
    woodhawg
    1. S.F.C.C.
    I don't run one on my car. No problems
    squirrel likes this.
  22. OLDSMAN
    OLDSMAN
    I would say if you had a quart recovery tank that would be plenty
