Radiator repair Q's
Discussion in 'The Hokey Ass Message Board' started by Goozgaz, Mar 2, 2007.
  1. Goozgaz
    Goozgaz
    I was about to leave on a trip from LA to San Fran this morning when I noticeed that I had a leak in my radiator. It's a pencil tip sized leak at the top of the rad (see picture below).
    Can I repair this with basic home plubming tools. (Propane torch, flux, solder)? WILL THIS WORK??
    I know that this is not the CORRECT fix, but I plan on replacing the whole radiator before Paso... I just wanted to get it out of town this weekend.
  2. squirrel
    if you do it like I do, then you'll make the leak worse, and chase it all over the radiator.....
    try jb weld for a temp fix. Clean the radiator very well first.
  3. Goozgaz
    Goozgaz
    I was thinking that a torch might just make the crack bigger or that the solder would not stick to the metal.
    JB Weld was my next question. What's the opinion on JB as a fix?
  4.
  5. AutoReWire
    AutoReWire
    Alliance Vendor
    I have had success doing this very repair using a large soldering iron AFTER cleaning the area VERY good and using lead solder with an acid flux. Most attempts with a torch were not very successful.
    Al
  6. Goozgaz
    Goozgaz
    OK. I'm going with JB Weld and I'm hitting the road.
    If you see a Lincoln on the side of the road this weekend in CA... pull over and slap me a few times. :)
  7. the-rodster
    the-rodster
    That location is usually pretty hard to fix even by a radiator shop.
    I had one on my walker at that location, where the top tank meets the core, and had it "fixed" by the local rad shop several times.
    I talked to Walker, they recommended completely pulling the top tank and resetting it, which they did, for only 50 bucks.
    Hope this helps.
    Rich
  8. squirrel
    a good radiator shop would have pulled and reset the tank, since that's the only way to fix tank/header seam leaks....sounds like your local shop is a bit lacking?
  9. Goozgaz
    Goozgaz
    Adios mama... me voy para el norte!
