1952-59 Ford Radiator side air deflection panels
Discussion in 'Off Topic Hot Rods & Customs' started by 40cpe, Jul 4, 2019.
  1. 40cpe
    40cpe
    from Star, MS
    Does the '55 have these rusted pieces in the attached picture? '56side air defection panels.jpeg
  2. fiveoh108
    fiveoh108
    Yes, my 55 has them
  3. 40cpe
    40cpe
    from Star, MS
    I just looked at my '55, I guess whoever put it together decided it didn't need them. What is their purpose and the consequences of not having them?
  4. 55customlinecowboy
    55customlinecowboy
    The fender around the grill surround bolts to them. Mostly structural I guess. My 55 and my 56 parts car have them.
  5. fordsbyjay
    fordsbyjay
    from Lafayette
    What keeps your fenders and radiator from flopping all over the place?
  6. 54vicky
    54vicky
    I think a close look will show they are there other wise as asked what holds the fender.I think the hood catch panel also bolts to that.
  7. 40cpe
    40cpe
    from Star, MS
    They are there. I didn't expect them to go out so far as to tie into the front of the fender. Thanks
    fordsbyjay likes this.
  8. 54vicky
    54vicky
    they are hard to see as you now know with grille etc.in place
  9. They are the air deflectors too... the tunnels for air to cabin start there.
    They bolt to the apron, bottom of the headlight bucket on the fender and the top where the hood latch connects.
    Mine were knackered like those.
    Having nothing to match them too I repaired them like this.
    Rui likes this.
  10. The real problem with this design is that the front wheel flicks up dirt and **** and it sits in the bucket that gets made where the fender meet the bottom. Unfortunately this means that they rust out pretty quickly below the headlight.
  11. fordsbyjay
    fordsbyjay
    from Lafayette
    And really bad above the headlight in the snow regions.
  12. What I can't understand from ford is why they made a splash guard for the rear end of the front fender well but not the front.
    Texas57 likes this.
  13. Texas57
    Texas57
    Ditto......that's why '57s at least almost always have rotted out headlight surrounds and need caps over the headlights.
  14. bobss396
    bobss396
    You'd almost want to install a clean-out plug towards the bottom of it, blast it out with a hose a couple of times a year. Use a standard Ford floor pan plug.
  15. speaking of rear splash guards... I just finished making a pair. Mine were AWOL.
    Made a pattern off a mates customline vicky and even used his swage and jenny to turn the sides up.
    Now I think the only panel thats missing on my vicky is the one that goes around the bottom of the radiator towards the motor... I'm also missing my y block "steady rest" but I'm not sure that they were always fitted.
    fiveoh108 likes this.
