radiator/spring cross member Help, Broke up real bad
Discussion in 'The Hokey Ass Message Board' started by Cyric30, Oct 21, 2006.
  1. Cyric30
    Cyric30
    from AR
    Hello All
    I amazingly found a 28-31 Model A Frame for sale close to home the other day so i picked it up and brought it home and am getting ready to make it usable again.
    The Bad news is the radiator/spring cross member is broke up real bad :( and would take Alot work to get wielded back togeather and im still not sure i would trust it with much weight, my question is does anyone have or know where i can find measurments for the thing to build one? (buying one isent an option right now) or another option to mounting the spring back in that area.?..i pefer not to go with a suicide set up due to this being a first build and am not wanting to get to fancy :)
    any help you could provide would be of great benifit and help to me
    Again thank you all for your help and patience i promise the results will be worth the trouble :)
  2. Ole don
    Ole don
    If the cars is a stocker, repair the one you have. They seem to work harden in use, but if you have a good welder do the job, they hold up well when repaired properly. If you do it yourself, work slowly, take your time, do your best, and if it doesnt work out, you had some welding practice, and you learned something.
  3. Cyric30
    Cyric30
    from AR
    Thanks Ole Don
    I may have to do that but im not comfortable with it, i tend to over think & engineer stuff some times though
