Radiator
Discussion in 'The Hokey Ass Message Board' started by 29HOTROD, Feb 7, 2010.
  1. 29HOTROD
    29HOTROD
    from Indiana
    Any suggestion on what radiator to use in a 1940 ford with a SBC.Try to find a cheaper radiator than a walker or other aftermarket radiator.Thanks
  2. roundvalley
    roundvalley
    Speedway Motors, Walker Cobra, 10 year gaurantee. $439.99. You may find cheaper but not better.
  3. Deuce Roadster
    Deuce Roadster
    I actually have good results with the STOCK radiator in my 40 coupe.
    I had it vatted and cleaned ... and had them install just one opening in the top tank ...
    283 bored .060
    10 to 1 compression
    aluminum intake
    and 55/56 Chevrolet exhaust manifolds.
    I did upgrade to a NEW alumnum Edelbrock water pump :D
    But I suggest a WALKER ... if your radiator is shot.
  4. 29HOTROD
    29HOTROD
    from Indiana
    Any stock replacements from other cars that are about same size?
  5. badlefihand
    badlefihand
    I bought from a shop in Michigan thru ebay,took a chance, all weld and looks like a good unit .Fit right in to my 47 and is direct replacement..Cant remember exact price but under $300 at the door.
  6. flamed34
    flamed34
    Take a look at 60's mustangs stock radiators. We just put one in our '47 Merc with a few modifications, but was close to stock dimensions. I'm sure there are others that would work as well, but we bought this still in the box at a swap meet for $25!
    For my '34 chevy, I purchased an original radiator off of Ebay for $35, and had it re-cored at an old timey radiator shop locally for $175 (I also had to have it shortened a bit to clear my crossmember. Way cheaper than a Walker, and allows me to run the "through-the-radiator-shell" filler neck.
    We did similar with our old '48 ford...had it re-cored and had one upper hose port and one lower hose port plugged to run with a SBC.
