Radiators
Discussion in 'The Hokey Ass Message Board' started by procrastinator, Feb 25, 2010.
  1. procrastinator
    procrastinator
    I been lurking this site for over a year now. Currently building a 29' tudor. I plan on running a 32' grill shell using a chevy 350, from experience what radiator fits best on those grill shells?? thanks, Louie
  2. Deuce Roadster
    Deuce Roadster
    I have found that Walker radiators FIT the original 32 Ford shells PERFECTLY :D
    You might want to consider using a ZIP's raised water pump riser also ...
    So you can use a large mechanical fan.
    Add a Walker fan shroud on the back of the Walker radiator ... and you are all set
    Mine runs 180 degrees ... ( right on the 180 thermostat ) in traffic, on the highway ... where ever ... even just sitting still in traffic for 20/30 minutes ... ( like coming out of the NSRA Nationals :)
  3. YBlockCruizer
    YBlockCruizer
    I'm using a '65 Mustang Radiator in my '29 shell. Fits good and the price is around $150 compared to Walker's $450. You might want to compare '32 and '29 shell dimensions. Good Luck on your project....Steve
  4. Reds 29
    Reds 29
    A '29 cowl is not as tall as the later model A's and will not line up with a 32 shell. The radiator and shell will be taller then the 29 cowl and I think it will look rather strange. A hood would also not fit. You could run a shortened 32 shell and radiator. I have a 29 coupe and run a 29 radiator from Walker and stock shell and don't need that riser shown in another post.
    Red
  5. hotrod56cars
    hotrod56cars
    '64 Mustang radiator in my '32 shell, it was less than $50 on eBay. If you run a Mustang radiator it will take some fabbing to mount it and make it look OK. The search function is your friend.
  6. procrastinator
    procrastinator
    Thanks for the help. About the 64-65 mustangs. I heard the v6 ones dont cool enough and the v8 radiators are too big, so which ones are good ones, the v7's??? ha ha ha. thanks for the help again.. Louie
  7. Hotrod1932
    Hotrod1932
    from Oregon
    1965 Mustang v8 Radiator works great. $130 at Autozone..
  8. carkiller
    carkiller
    Im running a lowboy 32 shell with a 65 mustang radiator.
