radio w/o engine noise!
Discussion in 'The Hokey Ass Message Board' started by brokedownpalace, Mar 21, 2010.
  1. brokedownpalace
    brokedownpalace
    from indiana
    wondering if any one can tell me how to get engine noise out of my radio? my old truck has a orig. looking radio w/ new guts. satellite radio is all ive got hooked to it. still cant hear my dead. any suggestions?
  2. chaddilac
    chaddilac
    one old way is to take your ground to the battery.
  3. zman
    zman
    from Garner, NC
    It can be a ton of things, ignition wires, non-resistor plugs, picking up noise from wiring that is close to the radio. Sometimes you can put a filter on the power side and get rid of it, but I try to track down the problem...
  4. hotrod40coupe
    hotrod40coupe
    You need to run spiral-wound or induction-type plug wires. You might also need to run a noise suppressor on the ignition and generator/alternator.
  5. 29nash
    29nash
    from colorado
    Yep. Also, run shielded power and ground wire to the radio if you have some.
  6. brokedownpalace
    brokedownpalace
    from indiana
    thanks for the quick response... my plug wires are new, body is grounded, engine is grounded, radio is grounded, i just hooked up a noise suppressor in-line with my power lead but it makes a loud noise every few seconds i have the radio on. if i hook it up the other way radio dosnt come on. i know im not doing something right. the radio power is coming off the back of my guages, is this ok? do i need to run that wire some where else?
  7. zman
    zman
    from Garner, NC
    Do you have a fuse box? If so you can run one from an acc. circuit. I'd be worried about pulling power from the back of the gauges, what is the power there for? lights? amps?
  8. flamedabone
    flamedabone
    You need what is called a ground loop isolator. You can pick one up anywhere that sells stereo stuff, even Wal-Mart. They go for around 25 bucks and will cure 95% of your problem.
    Good luck, -Abone.
  9. brokedownpalace
    brokedownpalace
    from indiana
    not sure about the gauges, just know that its hot when key is on. only guage that works is the temp anyway...thank you though for the suggestions, ill get it figured out
  10. brokedownpalace
    brokedownpalace
    from indiana
    it has a 12 volt system, has cl***ic instrument guages, pretty sure there 12 v as well. the noise suppressor says:
    model: cap 50m
    16vdc 50,000 mf computer grade
    electrolytic capacitor
    i have no ides if its even good, a buddy gave it to me, told me to hook it in-line w/ the power wire. one way i hook it up the radio works, but it makes a loud noise every few minutes. the other way i hook it up, the radio dosnt even come on.
  11. brad chevy
    brad chevy
    BACK in the day we just ran a condensor off coil and that cured the problem or you can run positive power wire to battery with fusible link and good ground.either way works.
