Radir spindle mounts
Discussion in 'The Hokey Ass Message Board' started by merryknees, Jan 4, 2014.
  1. merryknees
    merryknees
  2. I didn't think you could run disc brakes on those. Are you modifying motorcycle discs to run up front or has someone made a kit for those?
    I don't know if this will help, but do the spindle mount rims have races for the bearings already installed into them? If it does, you can take the races out of one rim and narrow down your search by looking through a bearing catalog and finding the popular pairings of bearings to that race. You're bound to find a bearing that matches the same diameter of the spindle shaft for both the inside and outside races. This method takes the longest, and it has no real guarantees, but its a better start than from where you began.
    Best of luck, Chap.
  3. Ask Radir - they can supply or direct you to where to find bearings and brake kits.
    Steve
  4. pnevells
    pnevells
    Radir has all the bearings and seals he even includes a neat piece of PVC pipe to tap in the dust cover, Mine were drilled for rotors ,
  5. toxic waste
    toxic waste
    from Iowa
