COE rain gutters??
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Aug 16, 2016.
  1. wetskier2000
    wetskier2000
    from NH
    I needed to pull away the forward lower 6 inches of rain gutter from the COE's A pillar to install the donor cowl panel. I'm debating if I want to put that 6 inches back or just shorten them by that amount. The truck will be driven in weather eventually so I don't think removing the gutters entirely isn't an option. Cutting off the 6 inches will place the forward bottom of them above the window opening.. Not sure if that's going to make rain pour in or not... Ideas??
  2. gentrysgarage
    gentrysgarage
    from LA CA
    I think the manufacturers found they did little good while driving, but was useful in keeping some rain off the driver when exiting, so they were shortened. I would vote for shortening them to alittle lower than the top. I think it would clean the lines up subtly. You might have to add a thin strip of metal to keep the door gap right though.
