Hot Rods Raised Flathead Motor Mounts
Discussion in 'The Hokey Ass Message Board' started by krylon32, Feb 13, 2022.
  1. krylon32
    krylon32
    from Nebraska
    I'm doing this super low 32 ch***is and am struggling with the front motor mounts. I'm using my 409 to FH pump kit and need to raise the motor about 2 inches. I could have some spacers machined but I'm looking for something more creative. The problem raising the mounts is the narrowness of the frame and the clearance for the hood. Anyone got any ideas? Thanks
  2. Bandit Billy
    Bandit Billy
    Build em and bolt em on. I built mine from SS and sunk threaded stock through the frame and welded the bungs through the boxed frame. 3 bolts on each side and they come right off so I can drop my flathead through the bottom for the frame with out removing the front sheet metal or hood. If your frame is unboxed this may not work but I think a cool pair of raised mounts all drilled and polished would look cool.
    Pist-n-Broke likes this.
  3. I have a very Fertal mind but if I want anything worthwhile coming out, I need a photo of where we're starting from. Post up some photos and let's see what happens.
  4. nobby
    nobby
    jaguar s type
    3.0 petrol
    engine mount
  5. BJR
    BJR
    petrol?:eek::D
    Tman likes this.
  6. krylon32
    krylon32
    from Nebraska
    I've built countless Flathead deuce ch***is using the standard biscuit and weld on frame mounts which is fine for a normal ch***is. This ch***is has a 5 inch dropped axle, flat front cross member and super low front spring. That's why I have to raise the motor and trans. Trans is easy but something that looks good under the hood is a challenge. I'll figure something out just looking for others ideas.
  7. redo32
    redo32
    I know you follow Steadfast and we all marvel at his creativity.
    118444934_312856626464403_1482212512800213223_n.jpg 130299482_189026159605120_4062326984888819714_n.jpg
    Bandit Billy, rod1, akoutlaw and 6 others like this.
  8. Wow man,,,,,that mount there is a work of art !
    Tommy
  9. krylon32
    krylon32
    from Nebraska
    Those handmade Steadfast mounts are the best. He's showed them on his Instagram page in their raw unfinished form and the number of pieces involved is unbelievable. He's an artist. I've made lots of parts so we'll have to see what I can create?
    vtx1800 likes this.
  10. Being you're not stuck with the mount ears on the Flathead water pumps I would think you could come off the front of the blocks 32 mount holes and do a low drop version of the Hurst S.B.C. unit and put the tabs about any place you want them unless the 409 pump blocks them. I've never actually seen the 409 pump on a flathead so no idea if it blocks the tapped holes or not.
  11. rusty rocket
    rusty rocket
    Gary, this is what I did when I built my T modified. Sorry for the crummy picture. F31EB043-98D6-4DA4-A58A-1A237F2820F5.jpeg
    Tman likes this.
  12. walter
    walter
    Gary
    I used 49 Mercury mounts which raised the front of the motor almost 2 inch's
    Hamtown Al and warbird1 like this.
  13. goldmountain
    goldmountain
    Those biscuit type mounts use 7/16" NF thread bolts so I dressed mine up on top with chrome acorn mag wheel nuts.
