Ralphs 30 Roadster on 32 Rails.
Discussion in 'The Hokey Ass Message Board' started by Flop, Oct 12, 2011.
  1. Flop
    Flop
    got both motor mounts in but only one side kinda finished . well the prior design turned into something else because the grinding became too intricate and nothing could grind into the detail i came up with so the new design came into play after everything was welded up and this just kinda happened.
    i still have to turn a piece out on the lathe to move the rubber mount up . more on that later on .
  2. hotrd32
    hotrd32
    from WA
    Lookin good..........Flop!
  3. chopt top kid
    chopt top kid
    The new design more closely goes with the rear crossmember, IMO... I like it!!!
  4. Flop
    Flop
    Couldn't agree more chop top! Glad they came out the way they did.
  5. K13
    K13
    I think I like the way they came out better than your original plan as well. Less cluttered. I think simple always looks more factory. Great work!!
  6. edwardlloyd
    edwardlloyd
    from Germany
  7. edwardlloyd
    edwardlloyd
    from Germany
    This looks very like a roadster I'm building. I'm at the final put it together stage now but it was a hard 5 months work, I'm telling you!
    Ed
  8. Flop
    Flop
    very nice work ed !! i have never see your thread about the A crossmember before . i really enjoy making it look like it was supposed to be there !!
    finished up the other mount this after noon . boxing plates soon!!
  9. Jeem
    Jeem
    Alliance Vendor
  10. jeepers00creepers
    jeepers00creepers
    Most of us can fabricate something that will work, but few have the artistic view to make it not only blend in, but make it look amazing! You my friend have that talent! Keep up the good work!!
  11. Flop
    Flop
    thanks guys !!
    heres what im into today .
    made these on the lathe . first thing i ever made. well more or less helped a good friend as he made them
    here they are in action acting as a riser .
    the way henry would have installed a remake of his A crossmember.
  12. lowsquire
    lowsquire
    from Austin, TX
    Looks great!, I have one question, how does that mount work?
    if the bolt is tapped into the piece you turned up,or bolted through it, that mount is not acting as it was intended to, and vibration from the engine will be directly channeled from the water pump, and into the ch***is. you need to have the underside of the big silver piece resting on a flat plane, and the piece below it under the flat plane, with the step facing up, and through a large hole. That way the bolt is seperated from the frame by the sandwiched rubbers, and vibration is absorbed, as Henry intended.
    Please dont take this as criticism, just trying to help.
  13. Flop
    Flop
    i still have 1 more piece to make and weld to the top exactly what you are describing lowsquire the mounts are just visually taking up space . just couldnt figure out a way to get it all in one piece .
    no criticism at all!!
  14. Frenchy Dehoux
    Frenchy Dehoux
    Very nice build great work will keep following your progress.
    Frenchy
  15. elmitcheristo
    elmitcheristo
    Looks great! Just curious as to why the engine will be sitting so high. Is it purely for aesthetics or??
    -Mitch
  16. GARY T.
    GARY T.
    from S.W. Pa
    Why are you positioning the engine up so high off the frame?:confused:
  17. Flop
    Flop
    thanks mitch & frenchy.
    nothing short of aesthetics .top of the carb hits right below the top bead on the firewall .
    i want to fill the engine compartment a little more visually instead of the motor sitting low slung.
  18. lowsquire
    lowsquire
    from Austin, TX
    Cool. I lifted mine too, heres how it looks. the mount bolt goes up through from underneath.
  19. Flop
    Flop
    time to start boxing and smoothing
    crossmember welded and ground smooth
  20. Flop
    Flop
    started boxing ralph's frame.smoothed out all the transitions as well .
  21. Tank
    Tank
    I'm likeing this so far!
  22. Flop
    Flop
    thanks Tank!
  23. Flop
    Flop
    both sides finished up !now its time to get the body off the frame and box the middle portion .
  24. Flop
    Flop
    frame is pretty close to being finished up . have to c notch it and put the las set of boxing plates in .
    finished up the a crossmember yesterday
  25. Wow, that thing is looking kick ***, Tom. How's the new shop working out?
  26. slobroy
    slobroy
    Nice build, subscribing.
  27. Flop
    Flop
    still gettin situated Ray . unpacking between working !!
    thanks slobroy
    put the spring back together with a few leaves left out and put it where it belong!
    time to get an eye pleasing notch worked out !!
  28. Flop
    Flop
  29. MIKE-3137
    MIKE-3137
