The work you have done on the ch***is is fantastic im looking forward to the rest of the build . The notch on the rear looks factory cheers paul
thanks Mike! thanks Paul ! notch on the other side in the process of making the curve mig mig mig no comment some grinding to do !
That sure is one fine frame - looking forward to the upcoming centre cross-member and all the remaining ch***is details. Please keep the posts coming. Cheers.
Damn, your car is coming along quite well! Keep at it! Can't wait to see it all done! Love me an A Roadster on Deuce Rails!
thanks everyone . big big big push coming soon tons of parts headed my way !! what else is there to do thanksgiving morning besides push the roadster outside !? its crooked.. body is not attached in any way
Your pic looked familiar to me and then I remembered why..my old mock up pic...anyway, your roadster's looking great!
thanks Mike! uhhhohhh! ralph went with a cornhusker kit to bolt a t5 to the back of his flathead a small trim was needed since i raisied the motor up an inch and three quarters plenty of room for a fan !
Great job FLOP. You're making it look EASY! (We all know otherwise). Why are the rubber biscuits on top of the spacers?
thanks grease! in my opinion i think either way will work the same . rubber is under the mount as well isolating the frame from vibrations but mounting surface is raised and inch and 3/4
body off again body on body off !! welcome to a model A project ! time to start filling in the holes on Ralphs car . gonna add some to the pete and jakes crossmember 3 down and 3 up
Same body with two different cowls? I like the one with the V'd windsheild, is it a 30-31 Commercial cowl ore one you modified? Great work as always. Bob
that's one ***y roadster you got there.nice clean fab work.i hope to do a 30-31 on a duece frame someday.you got me watchin.
from paper to wood to a bracket on the banjo !! heres a few in between shots using the newest cutting technology . a grinder and a hole saw!!
Flop, We share most of the same cutting technology....I splurged on a recipricating saw though! Ha Ha!
hah good to hear greaser! hmm this channel seems to be in the way now much better !! yessir!! Sittin like a HOT ROD!! still have to get the front subframe connector out and flattened .
thanks skaterman!! started the ****** mount today ! a little cardboard always helps now i need some tacks welded up .. guessets will also be added in to the mix tomorrow
