Projects Ralphy's Tub
Discussion in 'Traditional Hot Rods' started by 29Hiboy, Aug 5, 2015.
  1. dumprat
    dumprat
    from b.c.
    Wonder if all these Ford flatty guys can run em at 120k for a couple of hours on a hot day?
    Maybe we should find out?
    Sounds like a challenge and the start of a great new event I have cooked up.
  2. Bader2
    Bader2
    Mine runs 170 on 185 stats on a 28 degree day! Up to 190 on a really hot day,where it has trouble is slow moving,needs airflow.Not horrible id say,you?
  3. 29Hiboy
    29Hiboy
    Good Photos 1Shot. I really like your interior.
    Is the tube shown the brace? Question - what did you do for door latches and rubber bumpers and could you take a photo. This car already had some sort of aftermarket latch installed but needed some re-working. I haven't installed dovetails which I'm not yet convinced it needs.
  4. 29Hiboy
    29Hiboy
    Sorry I missed your question - a year ago! I wish I wouldn't have as your heim joint idea is a good one. So far the cables run through the "looms" welded to the crossmember as you can see in the photos but they are still just d****d across the rear wishbones enroute to the backing plates. The body has to come off for paint eventually. I will tie them down then - maybe with brackets and heim joints. Sorry for the missed comment.
  5. 29Hiboy
    29Hiboy
    Nice car! Next tub I build will be a phaeton like yours. I am searching locally for an original.
    PurdueSD likes this.
  6. dumprat
    dumprat
    from b.c.
    You need to post an update...........
    Bondo Slinger and PurdueSD like this.
