1952-59 Ford Ram horn exhaust question
Discussion in 'Off Topic Hot Rods & Customs' started by Joe-Racer, May 19, 2011.
  1. Joe-Racer
    Joe-Racer
    Will the ram's horn exhaust manifolds, from the y-block truck engines or aftermarket either, work on a '55 or '56 SW? Manual or auto.
    Thanks,
    Joe-racer
  2. danman55
    danman55
    wish they could...the station wagons have the same frame setup like a p***enger car, and unfortunately, because of the way that the frame/motor mount/engine attachment works together, you have too much in the way to even bolt them on, much less get that exhaust down pipe to fit. Will not work. sorry.
  3. Joe-Racer
    Joe-Racer
    Well then! I knew it didn't look possible, but I thought I'd seek wiser counsel. What are some options, or are there any?
  4. Joe , you either need to sit down and build a set of headers ( I did a real simple set for Michelle's wagon) or hunt out a pair of thunderbird manifolds . Rod .
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Or contact Red's Headers they do fit well.
