Just a quick mention in case you're swapping parts over. The American had a different mounting pattern for manual versus a power box. If by chance you're upgrading to a power unit - be sure you get the factory adapter bracket. For the '64 American it is a sorta trapezoidal (sp?) looking thing that is made from steel. The later traingular 3bolt aluminum ones aren't gonna work. I recently went through this when I upgraded my '64 American to power steering. Good Luck
If you need help with Ramlers/AMCs, here's a link to a forum that should help. http://amccars.net/cgi/yabb2/YaBB.pl
That's what I'm going to be doing is updating my '64 American. The "factory adapter bracket" would be the one from the later model unit right? Just want to make sure I get it right. Thanks.
No that LATER MODEL one is the triangular aluminum gizmo - won't work I tried. Your's is a goofy looking trapezoid looking one - I see them on Ebay on occasion - they are at times hard to find, but often go cheap as there's not alot of demand for them. The Column is also different.
