Technical Ramhorn Chevy Manifold
Discussion in 'Traditional Hot Rods' started by Randy Rollins, Jul 24, 2024.
Tags:
  1. Randy Rollins
    Randy Rollins
    I read earlier of a fellow needing a ramhorn that turned inward. I needed that too. You get regular ramhorns that go straight and saw off the flange. You get a 45 degree 1-1/2
    Inch plumbing elbow and braze the elbow in. Between the flange and the ramhorn at whatever twist you need or you can buy blockhuggers whatever floats your boat!
    JohnLewis and Tow Truck Tom like this.
  2. deucemac
    deucemac
    Look for late 60's truck and full size p***enger car drivers side manifolds they are ram horn with a 45° turn back and fit applications where the steering gear is in the way
  3. bobss396
    bobss396
    Both mine are 45 degree with my SBC swap, the driver side is a '65-'68 full size Chevy, p***enger side is a new Dorman piece with all the fugly nubs, etc ground off.
    Tow Truck Tom likes this.
  4. squirrel
    the late 60s full size cars used one turned back manifold, the 67-72 trucks used two.
    Neither of them will turn "in", though.
    Tow Truck Tom, Fordors and JohnLewis like this.
  5. blue 49
    blue 49
    from Iowa
    Mine is offset in slightly, maybe 3/8-1/2". Just enough to clear my steering shaft by 1/4".
    Gary
  6. Xdrag48
    Xdrag48
    Dorman 1972 C10 manifolds, they don't look like the turn in just back. Left side # 674-201 Right side # 674-199
    bobss396, alanp561 and Tow Truck Tom like this.
  7. 34Phil
    34Phil
    angle mill the flange, spot face the bolt holes if you think it's needed
    I just offset my engine 1/2" to the p***enger side and milled and filled the Olds valve cover like BBC ones to clear the steering shaft.
  8. krylon32
    krylon32
    from Nebraska
    I've used the early C10 left side manifolds on several SBC powered deuces with Vega steering. I found they tuck in toward the motor and point back just enough for the steering shaft to clear the exhaust. On the right side I like the straight down manifold as the one that points back at a 45 degree angle gets cozy with the starter.
    blue 49, pprather, alanp561 and 2 others like this.
  9. bobss396
    bobss396
    I have the 674-199 on my car, Ebay, open box shipped for $49. Ground off the ugly, installed plugs for the AIR holes and painted it with POR15 manifold paint, looks fact-tree.
    deathrowdave likes this.
