random things you remember.
Discussion in 'The Hokey Ass Message Board' started by bigblock225slant6, May 11, 2009.
  1. boldventure
    boldventure
    a buisness card is the right gap for a Yamaha KT-100 ignition module
  2. ahahah, this is great ****, keep it coming.
    you know, if we get enough we should all make a tiny "**** you might wanna know" book and print out a few to hand out during car shows.. might catch on.
  3. LAROKE
    LAROKE
    Damnation! Maybe I'm having a senior moment . . . and why are my shoes on the wrong feet?
  4. LMAO!!!:D After 50 that's pretty normal. ;) Payday!!!:D what month?
  5. Paratrooper?
  6. Accel Turbo chargers
    Traction action traction bars.
    Nov 22 1963. (9th birthday-JFK shot)
    437 mph-P-51 D
    $17.00 first dash mounted tach for my first 66 Mustang.
    1971, year I got the Mustang. 2 barrel 3speed 3:50 gears. Red notch back. 1,000.00
    16.45 @ 85 mph. First et with said Mustang at Wichita IR
    Oct 9th John Lennon's birthday
    Oct 10th 1995 First daughter born.
    Dec 8 1980, John Lennon murdered.
  7. teisco
    teisco
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Get the ATIS information 10 miles out from entry into the airspace, contact the control tower for that airport, and state the following:
    "tower name, aircraft tail number, location, al***ude, Landing with information whatever "ATIS" code you received above." The tower will instruct you to take left (or right) traffic for Runway X and to report on 45.(This is a rough guideline, its missing some specific information that tower sometimes asks for)
    Do your prelanding check with your checklist: Mixture full rich, Fuel selector on both, Suction indicating, Oil Temps. and Press. (Ts&Ps) in green, Master on, Mags on both, Harness' locked and latched, Landing lights on. PLANE CLEAR TO LAND
    Apply Carb. Heat and make your descent to where you reach pattern al***ude for that airport by the time you reach the 45° entry leg. You can be a little higher on the 45. Let's ***ume the pattern al***ude is 1200 feet MSL. Try to descend at 500 fpm. That will be easier on your ear drums.
    Reach the 45 and contact the tower and tell them how many miles you are out on the 45 and your al***ude. The tower might clear you to land or will acknowledge.
    Remember that when you reach 1/4 mile from the runway, turn downwind. By now the tower should have cleared you to land. You should have slowed the plane to 80 to 85 knots and powered the engine to around 2000 rpms.
    Know that when you are abeam the runway numbers, turn on your carburetor heat on,(unless power plant is injected as my 172XP has continental 6 in it) power back to 1500 rpms, and extend 10 degrees of flaps. Lower the nose to begin a 500 fpm descent The airspeed should drop to 75 knots. Make sure you coordinate your turns with the rudder pedals.
    Learn that the threshold of the runway is 45° behind you, turn left base, and apply another 10 degrees of flaps. This should bring your airspeed down to 70 knots. You are now perpendicular to the runway. Make sure you don't overshoot your final turn because the parallel runway might have landing traffic.
    Turn Final. While on final, your approach to be stabilized. Use power to control your al***ude, and pitch to control airspeed. Try to approach at 60 - 65 knots. When you are on short final, extend 10 more degrees of flaps, and aim the plane for the threshold. Do not let the plane go below 60 knots. Use the rudder pedals to keep the plane aligned with the runway center-line.
    When you are a few feet off the ground, gently power back and raise the nose, and allow the wheels to settle onto the runway. Power back all the way, apply full back pressure on the yoke, and brake if necessary. The brakes are located above the rudder pedals. You are now on the ground.
    this is drummed into your head durring taining..no getting it out
  9. 41woodie
    41woodie
    B710724 - Navy Serial Number
    $3125.00 - Price of first new car I ever bought.
    Bobbie Lou Deetz - Name of my second grade teacher, who I had a serious crush on.
  10. twenty dollar!! boom boom long time!!:D
  11. GUMPS
    Crabbing.
    13,000.00 my 89 5.0 LX Mustang , Loaded.
    12.09 @ 110 mph. my `80 GS 1100 with fairing at the drags
  12. Hack Attack
    Hack Attack
    I remember a lot of paint code numbers.
    For paints that they dont even produce anymore!
    Thats kind of some unless knowledge.
  13. bulletproof1
    bulletproof1
    from tulsa okla
    i cant remember names to save my life ,but i can remember seeing old cars in fields,creeks, behind houses out in the middle of nowhere ...and find my way back to them years later..example when i was 8-9 my dad had a friend that played in a band he would have big partys and get togethers on his farm.....behind the barn where a bunch of cars...last summer i asked my dad about him ..the cars are still there....
  14. Chryco bleeder screw 3780788....return spring 4027590....a customer 25 years ago ,his plate number OLE 519.The strange **** I remember.
  15. temper_mental
    temper_mental
    from Texas
    **** rolls down hill!
  16. Crankhole
    Crankhole
    Jenny's phone number
  17. Brian C
    Brian C
    When you take Natural Gas and reduce it's pressure you lose 7 degrees F in temperature for every 100 psi you cut in pressure.
  18. Ebbsspeed
    Ebbsspeed
    Rockwell hardness of Buick straight eight 263 rods is around 24-26 on the 1950 through mid 1952 motors, and the later ones, through 1953 Rockwell at about a 10. Same part number, but big difference is durability.
  19. Hyster
    Crown
    Eaton
    Yale
    Clark
    Hercules
    Towmotor
  20. Thorkle Rod
    Thorkle Rod
    18654372, or is it 18436572, or is 18536472 awh **** I don't know:confused:
    What I know is that I don't know what I used to know cause I know what I used to know wasn't so or what I knew is still what I still don't know.
    RCH593 was the license plate on my 61 Falcon G***er that I sold 30 plus years ago
    RBJ694 was the License on my 64 Pontiac that I traded in 1972
  21. 49ratfink
    49ratfink
    BJB 213. the plate number of the first car I ever bought 33 years ago. I've had my current daily driver for 10 years ... I have no idea what the license plate number is on that one. it's blue and yellow... that much I know.
  22. Jarred Hodges
    Jarred Hodges
    you always throw away stuff you will later need. I s****ped a 3 speed last year and am now trying to find another
  23. chappys4life
    chappys4life
    from Austin, TX
    Never tell a woman she looks fat in a dress lol
  24. mrpowderkeg
    mrpowderkeg
    "Towmotor" wow, I rebuild a continental flathead for one a few years back. Purred like a kitten, but the hydraulics would bleed down and the mast would tilt forward. Champion F9Y plugs for FE engines. the new superseded number is not the same, wind up pinging issues if they're used.
    Also besides the towmotor, I worked on a Badger Dynamics Bucky forklift as well... had fun finding parts for it. No one else seem to remember it http://i167.photobucket.com/albums/u154/mrpowderkeg/BadgerDynamicsBuckyForklift2.jpg
    Oh and the B&M hydrostick trans
  25. 61TBird
    61TBird
    MJS 486 -License plate of the '64 1/2 Mustang my Parents bought new.
    T 69 721 - License plate of my Dads '66 Ford truck he bought in '68.
    869 DEB - License plate of the '70 Chrysler Newport my mom drove.(They traded the Mustang in for this one....)
  26. dabirdguy
    dabirdguy
    KAR 120C was the license plate on the Prisoners car.
    Gravity causes an accelleration rate of 32 feet per second per second for falling objects which is STILL faster than my flathead Merc.
  27. TagMan
    TagMan
    I remember not to post useless threads when I'm bored.......
  28. lippy
    lippy
    from Ks
    If the fire is pink, the condenser is bad. :D
  29. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    My dad says...
    15-36-24...Great Keno numbers.
    Dynamo Hum, and Don't Eat the Yellow Snow...
    Robin Trower-Master of the Stratacaster
    Points on wico mag set at .012
    7154MC-first crystal for Novice transmiter
    Don't drink 3/4 of a gallon of Jack Daniels..
    He doesn't remember much after the Jack...
  30. Stockwell Forklifts, St Paul ,Mn
    1973 til 1977. Mechanic and Parts.
    Yale's, Old forklift's with Chrysler flatheads, slant 6's, One the Ford plant used with with a GMC V8.
    Crown Lift Stac and Stor
