1952-59 Ford Ranger rear end
Discussion in 'Off Topic Hot Rods & Customs' started by orangedog, Nov 16, 2023.
  1. orangedog
    orangedog
    I had my local auto salvage looking for a 89-92 ranger rear end. They found one, then had issues with shipping delays with the other salvage yard. It took 3 weeks to get it delivered. It showed up finally, but it's a 2001.
    Has anyone used the wider 58 1/2 in rear end with out issues. Does the offset chunk create clearance issues with the drive shaft. I running what I think are stock rims with 205 tires. As it sits I have 2 in. clearance between the finder lip and the side wall of the tires. I think I'll only loose about 1/2 in. tire clearance either side.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    They have been used in the past, the offset of the wheels you use are the key, later Ford wheels have a more positive offset that will put the wheel further into the wheel well, use this tech tip from the "Sticky" https://www.racingjunk.com/news/how-to-get-perfect-rear-wheel-and-tire-fitment/ The chunk offset should not be a problem if the car is not lowered too much. If you want a steel wheel try a mid 80s early 90's Crown Vic 15" wheel or a 15'' wheel from a Ford Ranger.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
  4. orangedog
    orangedog
    Thanks JeffB2. I have looked a several of the wheel clearance post in the sticky's. I do need to do some measuring while waiting on the salvage yard.
  5. jimmy six
    jimmy six
    If you’re installing the rear in your avatar it had a 56” wide rear. I thought the Ranger 8.8 was the same.
    My 8.8 has 11” F150 drum brakes and a 6”wheel with a 215-75-15 can be removed and installed but it’s real close. Be careful with your mounts as the tube has 2 different diameters or mine did.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    This link will give you all the specs for the Ranger 8.8" rear ends and how to I.D. them https://www.therangerstation.com/tech/ford-ranger-rear-axles/
  7. jimmy six
    jimmy six
    Looks like 90-92 Ranger is the best bet.
  8. 51504bat
    51504bat
    Probably harder to find but an 8" from a Maverick is the same WMS to WMS (56 1/2) as the '90-'92 8.8 from a Ranger. Have one in my '54 Ranch Wagon.
  9. orangedog
    orangedog
    Thanks guys. The rear end I received was supposed to be a 1991 which would have been 56 1/2in. The one I received is 58 1/2 in. I found 2 late 60 early 70 rear end at the Moultrie swap meet saturday but both were 4 lug. Also found a explorer rear end but the ratio was too tall plus it would need to be narrowed.
    Thanks jimmy six, I did notice the axle housing size change.
  10. jimmy six
    jimmy six
    Usually Explorer rears are from overdrive cars with 3.55-3.90 gears. The “tallest” is 2.74 which I have in my 56 Ford Victoria that came out of a Lincoln or 80’s Crown Vic. I don’t have an OD but do have a true 3 speed automatic and it’s perfect for my driving style.
  11. orangedog
    orangedog
    The rear I'm running has 3.54 gears and I have a aod. This is a nice combination for me.
    JeffB2 likes this.
