Technical Rant Lisle 16000 Cyl Hone
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Jul 17, 2023.
  1. seb fontana
    seb fontana
    from ct
    Instructions ****, Rant over.
  2. Seb, can I help with my exp.?
  3. winduptoy
    winduptoy
    Did you read before or after trying to use it.....question over
  4. jimmy six
    jimmy six
    Sorry to hear that. My 15000 hone worked perfect. Cylinder was absolutely straight and within .0005" with a bore gage on the one I had to hone .005" oversize.
    Truckdoctor Andy likes this.
  5. seb fontana
    seb fontana
    from ct
    Read instructions several times. 15000 and 16000 are different animals. 15000 is rack style [which I wanted but doesn't go small enough] and the 16000 uses taper ramps [ok with this] to get size. Instructions say to measure stones with a caliper and dress them if not parallel. Yes they can be made parallel to each other but not to centerline of body. They don't tell of the inner adjustment which will take out the taper but only at the intended diameter, which I have gotten the stones to w/in .005 from the .035 they were at at 2.5 dia. [Crosley, can't through hone] . They don't tell you there are different thickness stones to get to max diameter claimed which I found out by getting different grits and seeing difference when they arrived. Would be nice if adjustment knob had a few graduations. Would been nice if they posted the instructions [like summit does]. I'll get to where I want to be; I imagine in a 3rd world country it would be a Cadillac. Not too grumpy now. I need Gerital.
    winduptoy, jimmy six and 5window like this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Do you have a rotary table ? I'm thinking maybe a long shaft mounted grinding stone mounted in your mill..........kinda like a jig grinder set up. Indicate each cylinder true and lower the spindle till it touches. Move the mill table far enough to touch the ridge and then crank the table around. Here is a video of a true jig grinder. In your case you would just have a stationary shaft and the mill and rotary table would create the off center location. Then crank the table. It a good way to get all the way to the bottom of a hole.
    https://www.google.com/search?q=Jig...#fpstate=ive&vld=cid:df98cc1e,vid:xcIVPNCE2ko
  7. seb fontana
    seb fontana
    from ct
    A good alternative, I made a power drive for my rotary table and I do have long enough mandrels for the grinding wheels to mount in the spindle. Had a Moore just like in the video at work.
