Rare factory"Options"
Discussion in 'The Hokey Ass Message Board' started by Trichop, Mar 30, 2012.
  1. mart3406
    mart3406
    from Canada
    Regarding that 'top of the line' and
    otherwise loaded '59 Bonneville
    rag-top you saw with a lowly "three
    on the tree" - while it's a bit odd that
    someone would spend the money
    for a new Bonneville, plus pay a
    bunch extra for a lot of other desirable
    options and not go for a transmission
    upgrade too, it's not all that uncommon
    for cars of the era. In the late '50's
    and very early 60's , 4-speeds where
    just starting to become available as
    optional equipment on most American
    cars and where still considered to
    be somewhat "exotic" (Mopars, with
    the exception of a tiny handful of
    Chrysler 300 "letter cars" in 58, '59?
    and '60 that offered the expensive
    'imported from France', Pont-A-Mouson'
    4-speed, didn't even offer a 4-speed
    option until 1962) and the early
    automatics with a very few
    exceptions where considered an
    anathema for any kind of performance
    car. What a lot of the newer - ie
    - 'younger' car guys don't realize,
    about '50's and '60's vintage cars,
    is that back then, and right up until
    the about the early or mid -'70's too
    - that that if you ordered a new a
    car and didn't specify an optional
    transmission - ie - an automatic or
    a 4-speed stick - and also pay a
    couple of hundred dollars extra for
    the privilege of having that optional
    ****** - that on almost everything -
    regardless of the engine, that the
    default was a column-shifted
    three-speed manual This was on
    just about everything, even on
    hi-po packages and so-called muscle
    cars. Even Corvettes came standard
    with a lowly 3-speed stick (albeit
    and at least, always on the floor,
    though!), if the buyer didn't specify
    a 4-speed or an automatic and then
    also ante up a couple of hundred
    dollars or so extra to get it. About
    the only exception and even then,
    only from about the mid-50's and
    up, was some 'top of the line'
    dedicated luxo-barge Cadillacs
    Lincolns, senior Packards and
    the like, that had by then made an
    automatic transmission as standard
    equipment and in most cases then
    too, didn't even offer a manual
    transmission of any kind, even as
    an option. But on just about anything
    else, if the buyer, for whatever reason,
    didn't specify an optional transmission
    as an upgrade from the base, the car
    came through with the ubiquitous
    "three on the tree".
    Mart3406
  2. mart3406
    mart3406
    from Canada
    Not as neat or rare as a loaded
    421 tri-power, 4-speed Catalina
    wagon, but when I was a kid
    a neighbour of ours bought a
    new, otherwise 'plain-jane'
    '64 Beaumont (Canadian
    'Pontiac-badged and trimmed'
    Chevelle) wagon with a 220hp
    283, a 4-speed, dual exhaust
    and bench seat.
    Also, in the early 70's I had a
    '64 Chevelle Malibu SS with a
    built 283, (and later an even
    more radical 350) and a Muncie
    4-sp in place of the original 2-spd
    Power-glide. Shortly after I
    installed the 4-speed, I came
    across a wrecked '64 Malibu SS in
    the boneyard that had originally
    been 4-speed car, but had been
    converted over to a Power-glide.
    But when they converted it, they
    had left the original 4-spd console
    in place, so I grabbed that for my
    car, plus a fairly rare factory tach
    that was still in the dash. A bit
    later, I found another, non-SS. '65
    Chevelle in another boneyard that
    had factory power windows and a
    4.11 geared, 12-bolt posi rearend
    which I also grabbed and put in my
    '64 SS. What was weird about the
    '65 that I scavenged the power
    windows and the 12-bolt posi
    from was that it was a base-model
    6-cylinder Chevelle 300 with a
    3-spd/OD and almost no other
    options other than power
    windows (!) and a factory trailer
    towing package (!), hence the
    12-bolt posi rearend. And because
    the trailer towing package had
    been combined with a 6cyl and OD,
    the 12-bolt posi which otherwise
    normally only came on came the
    high-hp 300 & 350hp-327 V8
    Chevelles in '65, came with with
    4.11 gears too!
    Mart3406
  3. even funnier about those Buick Hydraulic windows is they only powered they front windows, the quarter windows were still manual. I've never underdtood the logic behind that. the hydraulics, 1 pump under the right front fender powered the top, front windows, and the seat.
    Cadillacs did offer the power quarter windows.
  4. stuart in mn
    stuart in mn
    The car in my avatar is a factory four speed, tripower car. That was uncommon enough for a Catalina or Ventura in 1961, but was quite unusual for a Bonneville.
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    I think the year was 1975, and yes, they did have a separate 110 volt alternator. They also had no defroster vents IIRC, and I was told someone had bought up all the windshields from Ford in the early '80's. My friend had one back then (T-Bird) and he was scared to death something was gonna happen to his windshield. One of FoMoCo's Better Ideas that didn't p*** the real world "Tough Test"
  6. mart3406
    mart3406
    from Canada
    One little known problem that
    brought grief to some owners of
    new Lincolns and T-Birds equipped
    with the"electric self-defrosting
    windshield" option was that the
    the thin gold film imbedded in
    the gl***, besides conducting
    electricity, also very effectively
    blocked radar waves, which
    rendered dash mounted radar
    detector units completely
    ineffective and unusable. Owners
    of these cars who had previously
    depended on their radar detectors
    to keep avoid police radar and
    keep themselves out of trouble,
    usually only found out about the
    gold-film embedded gl***'s 'radar
    blocking' ability when they
    suddenly started getting speeding
    tickets in their new car!
    Mart3406
  7. tempestan55
    tempestan55
    from Tempe, AZ
    In 1970, I had a '67 real stripper Camaro, which had no options, whatsoever. It was a inline 6 with bench seat and 3 speed on the column. At the time, not caring about the apparent rarity, swapped it to a 327, 4 speed, bucket seats, console. I've not seen any with 3 on the tree, and many "experts" have almost called me a liar. Pretty sure I was 3rd owner. Car had Chevrolet dealer sticker on tail light panel from Washington state. Anyone else ever seen one?
  8. G'day, We were out at a friends farmsted in MN looking at his old junkers. There was this ugly green 70 Camaro sitting there half stripped. It was originally I believe a 307 3 speed on the column car. No options at all. For some reason I looked under the back of the car and there was a 12 bolt rear with a silver tag on it. Couldn't believe my eyes.
    For lack of options, 1959 Corvette with radio delete, heater delete, no wipers and no evidence of holes ever being drilled in the cowl, and no front turn signals. Not even close to legal but who knows what happened that day on the ***embly line.
    ms
  9. Chrisbcritter
    Chrisbcritter
    My friend Charlie has a '54 Skyliner gl***top with power steering, power windows and power seat.
    My dad ordered his '57 Buick Century with factory air and an odd dove grey-over-black paint job, and blackwalls.
    Heading O/T, a friend of mine has a '69 442 convertible he bought new from the dealer's showroom (in stock, not special order) with a bench seat, column automatic, and factory 8-track. (Has 220k on it now, looks a bit ratty but still runs great and the engine's never been rebuilt.)
    Finally, I was in the Monrovia Pick-A-Part about six years ago and spotted a '62 Dodge 880 four-door hardtop with a certified (aka Police) speedometer, which I quickly removed to squirrel away. I should put the damn thing on eBay...
  10. mart3406
    mart3406
    from Canada
    Yep. Not common, but they made
    some and few people actually
    bought them that way.:eek: I think
    I've seen three over the years
    with bench seats and a column
    shift. - one 6cyl-3 spd manual,
    one 6cyl-Powerglide and one
    327-2bbl with a Powerglide - all
    '67's.
  11. Deuces
    Deuces
    Looks like it was a dealer installed item...
  12. Deuces
    Deuces
    That's a hillbilly air conditioner.... I got one on my Ford pick'em up truck.. :D
    lothiandon1940 likes this.
  13. Rot 'n Kustom
    Rot 'n Kustom
    I grew up in the White Plains, NY area, not too far from the Tarrytown, NY General Motors plant. In the seventies, the plant was producing Firebirds and Camaros. As cars came down the line, a little hang-tag on the door indicated what brand to make it.
    There were reports at the time that a few went out the door to dealers with Camaro fronts and Firebird rears and vice versa!
    I'd bet lots of these "rare options" were actually just cases of parts running out on the ***embly line or inattention to build sheets. They just needed to keep the lines running and send cars out the door.
  14. Bigcheese327
    Bigcheese327
    My dad said he'd seen one set up that way, or with a Powerglide and a bench seat, being driven by a young girl.
  15. jazzfidelity
    jazzfidelity
    wow, that's one 4-door i would have loved to have seen..
  16. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    my 57 chevy is a 210 2door hardtop. has v8 motor, auto, tinted windows and factory padded dash. They could have bought a belair for all that they added to that car.
  17. Bigcheese327
    Bigcheese327
    But their neighbors would have disapproved of them putting on airs.
  18. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Didnt know it was rare...... Looked at one in high school as a potential first car. Ended up p***ing on it due to needing to have a v8 if i was going to drive a camaro. 6banger, 3 speed and bench seat....
  19. Bigcheese327
    Bigcheese327
    What a sleeper that could have been with a powertrain swap, retaining a 3-speed.
  20. I guess I've seen a few
    1957 Chevrolet 4 door post injected 283 hp 283 dealer installed 4 speed
    1959 fuel injected 4 speed Impala
    1965 plymouth green 4 door, trailer package 426 Hemi
    1960 T bird sun roof 352 ci 3 speed overdrive I seen a few of these
    1950 Cad 2 door hardtop factory stick I've seen a few stick cads but this is to only HT
    1961 Pontiac 4 door factory 4 speed
    1969 Camaro 6, 3 speed column shift with a bench seat
    1955 Corvette v8 3 speed stick
    I have a customer that has a barn full of one off cars that I need to get permission to list
  21. You were posting the same time as me. the Camaro here in Oregon was green and might have been a 67 also thinking back
    The guy that bought the 4 door Hemi car was going to pull the hemi and junk the body till a friend stopped him. chrysler didn't show ever building a Hemi 4 door but this car had all the right numbers. the farmer special ordered it to tow a 30 ft airstream
  22. 30tudor
    30tudor
    Not HAMB worthy for sure but I once owned a '69 Chevelle with fiber optic turn signal indicators on top of the front fenders and fiber optic indicators on the rear shelf. This car also had a "traction control" package on it. For real, I had the build sheet also.
  23. flathead okie
    flathead okie
    Yep my younger brother had one in '77.
    I had a 64 Catilina with 389 tri power, power brakes, steering, and a/c, 3 spd column shift.
    Friends Dad had a 64 or 665 econoline van with 6 cyl 4 spd column shift.
    Ol' lady here in town has a 67 Chevelle wagon 396 4 spd.
  24. A couple *** kickers that were offered that I turned down
    A 70 Hemi Cuda (a real one) that had the hemi swapped to a slant six. $1500 I thought that it would never be worth the trouble to restore an old Mopar
    A 1969 Boss 429 (Semi Hemi) 4 speed car. all original ran good needed a a paint job I couldn't see paying $3500 and then paint on top of that
    and my favorite Dumb *** Me story. I traded my 51 Olds for a 1957 Ford 300 post car with a factory F series. factory suoercharged 300 horse 312.
    when I got the car it had factory dual quad set up rated at 271 horse. both are rare. but I had a friend that had a 327 chev powered Austin Healy that wanted the supercharger. I sold it to him for 10 bucks and then sat and bought both of us beer all night and went home broke.
  25. eddie1
    eddie1
    Completly off topic car. I had a 1980 or 81 Malibu in about 1989. Had a 305, turbo 350 & a factory power sunroof. No other option, has a am radio, no air, no power windows or locks, just the sunroof. The sunroof was metal not gl*** & I had never seen one before that car & have never seen another one with a sunroof since.
  26. flathead okie
    flathead okie
    Also 63 Falcon Sprint 260 4 spd w/ factory tach and vinyl top.
  27. tommy
    tommy
    I was looking at a 58 Edsel 2dr wagon, V8 3pd W/OD just a week ago with a factory tach. Cable driven off of the dist. I don't study Edsel's but I was shocked to see it.
  28. grease4life
    grease4life
    All time coolest option 1957 Cadillac Eldorado Brougham magnetic shot gl***es!
  29. 72hd
    72hd
    Had a 63 impala with 327 pg ac ps pb power windows & seat skirts posi dual rear antennas---------------also had a 65 impala 2dr ht with 409 4sd 12 bolt posi with 331 gears bucket seats console factory tach this car was Quick suprised many (pony cars} at redlights both cars were from the late 70s and are long gone
  30. 72hd
    72hd
    I remember seeing 1 in the mid 70s think it was a 68 but it had 6cyl 3spd on column bench seat 1967 or1968 camaro
