Hot Rods Rare flatheads at Daytona
Discussion in 'The Hokey Ass Message Board' started by Frank Carey, Nov 27, 2022.
  1. Frank Carey
    Frank Carey
    20221125_150530.jpg 20221125_112554.jpg .
    Two rare flatheads I saw at the Turkey Run.
    One is a 32 roadster with the original 21-stud flathead. The Eddie Meyer heads mount the water pumps on the front of the heads as the original did. And the Eddie Meyer dual intake is, I think, popularly known as the "slingshot" design. VERY rare pieces.
    The other is the small V8-60 that Ford offered from 37 to 40 and which never sold well. But the midget racers discovered it. This one has the extremely rare Offenhauser heads that use water manifolds.
    tractorguy, NoSurf, v8flat44 and 10 others like this.
  2. alchemy
    alchemy
    The roadster is still using the 32 water pumps. Those are rare items nowadays, and if the aluminum stuff doesn't drive the restorers mad, using the hard to find pumps will. Is it a 32 block?
    v8flat44 likes this.
  3. Frank Carey
    Frank Carey
    I don't know if it's a 32 block. Head mounted water pumps continued for several years after 1932. I don't know if later blocks were the same. Car owner was not available to ask.
  4. alchemy
    alchemy
    The easiest way to tell if it's a real 32 block is if the pet****s under the lower hoses at the front of the pan rail point straight down. Any year after 32 had a slight slant to the pet****s, but the 32's were straight down.
    I'd love to know that it's a real 32 engine with hot rod parts on it!
    v8flat44 and LOU WELLS like this.
