Technical Re-Drilling Ford Axle Lug Pattern?????
Discussion in 'The Hokey Ass Message Board' started by brigrat, Mar 12, 2025.
  1. brigrat
    brigrat
    from Wa.St.
    Looking to knock out the Ford 5 on 5 1/2" lug bolts and re-drilling to 5 on 4 3/4", who makes a jig or guide? Thanks!
  2. 31Apickup
    31Apickup
    Hells Gate Hot rods based here out of Washington. He took this over from Rotten Leonard.
  3. warbird1
    warbird1
    ^^^^ What he said ^^^ Though they are in Idaho...
    1971BB427, gimpyshotrods and brigrat like this.
  4. swade41
    swade41
    from Buffalo,NY
    It won't work on that axle with the access hole, I bought it and tried it, it lines up the 4.75 patteren right in the hole.
  5. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^I was wondering that, it doesn't rotate, it's a fixed jig?^^^^^^
  6. swade41
    swade41
    from Buffalo,NY
    I ended up just buying aftermarket axles with the 5x4.75 pattern, I also told them they should add that it won't work in these applications in their description.
    They did agree to take it back but I had to eat the shipping costs.
  7. ALLDONE
    ALLDONE
    i think dutch axel sell the axels with what ever bolt pattern you want... bout 7 day lead time what rear and axels do you have ???
  8. 31Apickup
    31Apickup
    My mistake
  9. RICH B
    RICH B
    Think Tuck had some posts somewhere on welding a disc in the hole, then having the flange trued on a lathe, then a slight groove marked at the new bolt circle, new stud holes laid out, and then drilled for new studs.
    Maybe the holes could be drilled and threaded and gr8 tap bolts used for studs.
    Saw stuff like this done way back in '60s Hot Rod article.
  10. ALLDONE
    ALLDONE
    wellll...thanks....
  11. brading
    brading
    You could weld a disc plug in the hole. Then use the Hell Gate drill guide. Then have the axle skimmed as per this article.
  12. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^ Thanks for taking the time to post that info!^^^^^^^^^^
  13. deathrowdave
    deathrowdave
    from NKy
    Thanks again also . I have plugged , faced redrilled a few . Worked perfectly
    bschwoeble likes this.
  14. ALLDONE
    ALLDONE
    why on earth would anyone go through all this when for 180 bucks you can buy thecorrect axel, and it comes with new bearing,seal and lugs
    gary macdonald and 1971BB427 like this.
  15. ALLDONE
    ALLDONE
  16. brigrat
    brigrat
    from Wa.St.
    ^^^^^^Because it's old school and money saved that can be spent elsewhere!^^^^^^^^^^^^
  17. RICH B
    RICH B
    ^^^^ and another reason to have a lathe in your garage.
  18. '52 F-3
    '52 F-3
    from Central PA
  19. brading
    brading
    If I was doing this I would make my own drill guide. First get an old hub or rotor with either the old PCD and new PCD. Re-drill or have this re-drilled to the other PCD. then take the centre out of it and use it as a drill guide like the Hellgate one possibly with the use of guides as of POST#43 in the link that '52 F-3.
  20. twenty8
    twenty8
    Aahhh, Gr***hopper.....
    Because the journey can often be more rewarding than the destination.;)
    '52 F-3, 19Eddy30 and X-cpe like this.
  21. ALLDONE
    ALLDONE
    ohhh...now i get it...thats how to spend 10-15 yrs getting a never done car
  22. X-cpe
    X-cpe
    Of course waiting til you have saved up the money never slowed any project down.
    warbird1 likes this.
  23. deathrowdave
    deathrowdave
    from NKy
    I have always said to myself if he can do it I can also . My time is free to me . I just worked 3 weeks wiring up a spool gun to my 200 amp MIG . It is 24 VDC operating and welder is 12VDC operating system . The spool gun was salvaged from work trash . 2900.00 new . I could not allow it to go to trash . I now can say , I did it and it works great . Could I have bought a new one , but why I have this one in hand
    '52 F-3, X-cpe, brading and 1 other person like this.
  24. brigrat
    brigrat
    from Wa.St.
    Seems we have a "Catalog Cowboy" a****st us!
  25. alchemy
    alchemy
    Just a doofus a****us.
    bschwoeble and VI Lonewolf like this.
  26. swade41
    swade41
    from Buffalo,NY
    It really depends on what you're doing with your car, sometimes a catalog aftermarket axle is a much better choice than a stock axle, it cost me a quarter panel
    19Eddy30, ALLDONE and Budget36 like this.
  27. ALLDONE
    ALLDONE
    I was gone at welding a plug and drilling a lug
  28. ALLDONE
    ALLDONE
    that would be me,soon as i get a catalog i'll know where all these parts were supposed to go IMG_3081[8924].jpg IMG_3166[8944].jpg IMG_3330[8998].jpg IMG_3338[9008].jpg IMG_3370[9034].jpg IMG_3371[9035].jpg IMG_3373[9037].jpg
    gary macdonald, brigrat and brading like this.
  29. 1971BB427
    1971BB427
    from Oregon
    I like saving money, but unless you have a lathe and can weld in the plugs I doubt you could get even the plugs turned smooth and bolt pattern drilled for what Dutchman's charges for new axles. And you'd still have old bearings!
    I could easily make and weld in plugs, but would have to buy the jig to redrill the pattern, buy new studs, have the mating surface turned, and get new bearings. Doesn't calculate as a savings to me.
    Rodney Dangercar, tjm73 and ALLDONE like this.
  30. brigrat
    brigrat
    from Wa.St.
    I was fortunate over the years to get a lathe, a mill., welder's, plasma cutter, etc. etc. for the shop and it wasn't because I needed more garage art to look at!
