Projects Re fiberglassing and reinforcing a fiberglass T bucket [help]
Discussion in 'The Hokey Ass Message Board' started by HI_TONE, Jun 26, 2015.
  1. HI_TONE
    HI_TONE
    Hey every I'm now building a t bucket I have a fibergl*** body that
    Has a cut out door. I have the door and I want to refibergl*** it in. Right now I am making a frame to support the body I have never worked with fibergl*** before and I am looking for knowledge on this subject please help
  2. HI_TONE
    HI_TONE
    Pics
  3. Hnstray
    Hnstray
    from Quincy, IL
    There are readily available books on this subject. You might check on line,.....Motor Books, eBay, Amazon and other sources. Fibergl*** is not difficult to work with, but does require basic information about the types of gl*** fiber materials that are available (cloth, mat, fillers) and their most appropriate uses. Also information regarding resin usage.
    Most importantly, SAFETY TIPS.
    Ray
  4. G-son
    G-son
    from Sweden
  5. 2racer
    2racer
  6. mike bowling
    mike bowling
    Trickiest part is mixing resin and hardener- if the proportions are way off it takes forever to be workable ( too little hardener) , or you get a "hot batch" ( too much) and 3 mins after you mix it, it "goes off" and is set up and useless. The materials aren't cheap, and it ****s to loose a batch because you're rushing the job. Start with smaller batches till you get a feel for it- it's not difficult. If you're sealing the door panel in for good, mat (chopped) fibergl*** is stronger, but harder to work with. Cloth isn't as strong , but much easier to apply ( and you can always do two layers.) You've got to get the door set in place exactly where you want it , then gl*** it from the back. "Paint" around the opening with the resin/hardener mix ( lay it on), then apply strips of cloth cut into 3 or 4" strips over the gaps.Paint on more resin and work all the air bubbles out with the brush. This is crucial to a good bond and a smooth finish. Worst part is if you get resin mix on your hands ( which you probably will!)- everything you touch will stick to your hands, and you'll look like Curley trying to put down the flypaper! Nyuk, nyuck, nyuk! Good luck.
  7. Phil1934
    Phil1934
    Neoprene gloves. It will eat latex ones.
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    I'm running to work right now, but tonight I will sit down and give you some tips on gl***ing. I have done a fair amount of it over the years.
    Don
  9. dan c
    dan c
  10. BLUDICE
    BLUDICE
    Make the door functional - believe me at some point you'll be glad you did. Speaking from experience.
    slack likes this.
  11. indyjps
    indyjps
    There's a lot of fibergl*** threads on here over the past few years and very knowledgeable people on this board. Do a couple searches and youll find the threads. I've done some gl*** work but it's pretty basic compared to others here.
    Get quality materials from a boat supply place, p*** on the auto zone bondo fibergl*** kit.
  12. prpmmp
    prpmmp
  13. RICH B
    RICH B
    Too bad it's on the driver's side. A right door is useful for both the driver and p***enger; while a left door may even be ***bersome for the driver, depending on steering and pedal location.
  14. spooler41
    spooler41
    prpmmp, Thanks for posting the West Systems pdf, thats just what I've been looking for.
    I'm going to reinforce a very ,old, light weight, gl*** '26 T roadster body, I've had for years
    Again thanks for the info. .......................... Jack
  15. prpmmp
    prpmmp
    Your welcome!! Get the video if they still have it,great stuff!! Pete
  16. flatheadgary
    flatheadgary
    from boron,ca
    i think your right about gl***ing in the door. it looks like it was just cut out and not a part of the original mold. it doesn't have the door flange for the hinges and such. the way i do it is, simply cut some steel sheet straps about 2 in by 4 in and pop rivet them across the opening of the door on the inside of the body. put the door in from the outside and pop rivet it to the straps. sometimes the body and door have sprung a bit so it may take some thicker straps to keep it square. also, it doesn't hurt to clamp a brace across the body to keep it stiff. then just gl*** around in between these and after they harden, drill out the rivets and gl*** it up completely. the correct way to do it would be to sand a trough were the separation is, about an inch or so both sides, so it will be a solid bond. this sometimes is not feasible because of the door revel. unless you want to reshape it afterwards. it also would not hurt to lay a couple of layers of cloth the full height of the body and as much as possibly fwd and back on the inside. to correct some thinking about gl*** fibers. the chopped strand mat gives no real strength. it is used to add bulk thickness. the cloth is what gives the strength. most hand layup is done with mat and usually a layup of cloth before the last mat, so if you have to sand it down, you will be sanding the mat and not the cloth. to use just mat is why chopper gun layup is considered not as strong as hand layup. after all, doesn't a gun spray the same thing your laying up in mat, just chopped up, you might also like to know, to get mat to lay down in 90% corners is to need it like bread dough and break up the bonding agent that keeps it together. this is used so it can be shipped and rolled up, otherwise it would simply be chopped up strands.
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    Ok, I have a little time this morning, so here is a little more info on fibergl***ing. There are two major components in the gl***ing process........the resin/hardener, and the cloth or mat. There are two kinds of resin:
    1) Polyester........the most common type, used in most boat and other things, like T bucket bodies. Your bucket was built with polyester resin.
    2) Epoxy resin........like the West System mentioned in an earlier post. Epoxy is superior to polyester in most respects, it bites in better, is stronger, and lasts longer, but it is also about 3 times as expensive as polyester. For most fibergl***ing projects it is not absolutely necessary. All of the work I have done on several T bodies has been done with polyester resin, and my 27 was done over 25 years ago and is still like the day I did it. But if you want the very best, no question epoxy is as good as it gets.
    The second component in the gl***ing process is the cloth or mat. The resin has no strength at all, it is simply there to stick the cloth or mat to each successive layer. When you apply the resin to the cloth or mat this is called "wetting out" the gl***. A properly wetted out gl*** is not too wet and not too dry.
    Here is the difference between mat and cloth:
    1) Mat is constructed of randomly positioned short strands of broken up gl*** fibers. You can take a piece of it and pull it apart with your hands. It has several advantages over cloth. It wets out better, so it sticks together better and it sticks to other things, like the wood you will be putting in your body for strength. It also goes around corners better, so if you have to have the fibergl*** wrap around a corner or over a piece of wood, it is better for that job.
    2) Cloth is the stuff most people are familiar with. It is long strands of fibergl***, tightly woven into a pattern. It is a lot like the shirt you are wearing. You can actually see where some strands run north and south and some run east and west. You can not pull cloth apart with your hands, you need to cut it with scissors. The downside is that it does not go around corners well and it is not great to use for the first layer as it can pull away after time.
    Both cloth and mat are used in the process. I like to lay down the first layer with mat, get it nice and wet, and then put either another layer of mat on top, or a layer of cloth down next. Sometimes, depending on how many layers you are doing, you can alternate between cloth and mat.
    When doing something like the door replacement of your T bucket, you will want to get rid of any of the old wood in that entire area and start with just a bare fibergl*** body. Remove all the wood, especially in the immediate area on both sides of the cut out portion. Grind the surface with something like an 80 grit grinding disc, wipe it all down with acetone, and make sure you have gotten all the old wood and gl*** off of the body inner structure.
    You will need to mechanically secure the cut out door to the body until the gl*** hardens. I would either use a lot of clamps or maybe even drill through the body and put screws into some temporary wood to hold it perfectly in alignment. Once you have the cut out door solidly in place, cut some wood pieces that will run vertically. Two of the pieces of wood should span the gap caused when they cut out the door.......some wood should be on either side of the cut.
    Everyone has different opinions about the wood to use. Some say oak, but I don't like it. I simply go to Home Depot and pick up some 1 x 3 or 1 x 4 strips of pine or other softer wood and use that. I think the gl*** sticks to it better and it flexes with the body better than oak would. Look at the picture I posted earlier (and I will post a few more after I get done writing this) and you will see how the wood goes and how it lends strength to the body.
    I used to wet out a couple of layers of mat, cut into strips wider than the wood pieces and I would put those under the wood to make it stick to the body. But there is a new product that is so much easier and better, it is West System Six-10 adhesive in a caulking gun tube. It is a lot like the structural adhesive body shops use to put body panels in place, and all you do is lay down a couple of beads and squish the wood down into it, clamp it down, and the next day it is part of the structure. I used it to put the firewall in my altered project and I love how it worked.
    Once you have the wood firmly gl***ed to the inner part of the body, you can either put a layer of mat over them to waterproof them, or paint all of the wood with resin. That will keep water from getting in and rotting out the wood.
    Finally, buy your supplies at a marine supply store and buy lots of throwaway brushes, a box of vinyl gloves, a gallon of acetone, lots of plastic mixing cups , lots of stir sticks, and buy your cloth and mat by the yard.
    I know this post is a little lengthy, but there is a lot to cover, and this only scratches the surface, but should get you started.
    Don
    gotmark73, LOST ANGEL and prpmmp like this.
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    These pictures might help:
    prpmmp likes this.
  19. seadog
    seadog
    Pay attention to what Don said...lot's of good info in his post. WEST system stuff is GOOD. Easily found at most boat supply stores. They even have a set of pumps for measuring the amount of resin/hardener that makes getting the correct ratio foolproof. If you're not near a boat store all their stuff can be found on line. Google West Marine for a start.
    prpmmp likes this.
  20. Shaggy
    Shaggy
    from Sultan, WA
    Have you tried tupperware forums??
  21. Canuck
    Canuck
    Just one tip:
    DO NOT WORK IN DIRECT SUNLIGHT, the UV rays will kick the mixture off quicker.
    Canuck
  22. dreracecar
    dreracecar
    from so-cal
    Gloves are a must---- because getting gl*** and resin on your bare hands makes you want to PEE
  23. prpmmp
    prpmmp
    Don!! Excellent Post!! Pete
  24. Epoxy will not break down the binders in fibergl*** mat, it works just fine with the cloth though. So sayeth the folks at the local suppliers. West System is a well respected manufacturer ,savior of many a boat.
  25. gimpyshotrods
    gimpyshotrods
    Ain't that the truth?!
  26. mike bowling
    mike bowling
    Safety First! Use all these materials in a well ventilated area ( preferably outdoors) and don't throw leftovers into a trash can and cover it. Keep the trash outside as well- when this stuff is curing, it gives off strong vapors and actually gets hot as it sets up. Works good, but it's nasty ****.
  27. Zandoz
    Zandoz
    It seems to me that there is bound to be gaps when fitting wood to the compound curves of a body. Don, do you know how much of a gap can be spanned using Six-10? Have you ever tried using ash for the wooding? Morgan still uses ash in their bodies. I know typically expensive, but I have a relative who operates a saw mill and has a good supply of ash drying. The main cost to me would be a couple of hundred mile each way trip to get it.
  28. Don's Hot Rods
    Don's Hot Rods
    from florida
    I think ash would be great, in fact, I think I bought some when I did my 23 and used it. As for the gap filling properties, I try to get the wood shaped as close as possible to the contour of the body, but Six 10 is thickened epoxy so it will fill quite a large gap. When I used it to put the wood firewall in my altered I had a gap of about a half inch on one side and I just pumped it full of the Six 10. Next day it was all one solid piece. Wish I had known about it years ago, but I think it is relatively new.
    Here is a little write up where they discuss how it fills gaps:
    http://www.westsystem.com/ss/new-six10-epoxy-adhesive/
    Don
  29. Zandoz
    Zandoz
    It looks like I'll be using ash with six10. Thanks for the guidance!
  30. flatheadgary
    flatheadgary
    from boron,ca
    another note on resin types. i have been working with a fibergl*** mold maker and he said not to use the commercial grade resin instead use tooling resin. a little more money but, one thing about commercial grade resin is it can warp with the body over time. the tooling resin is harder. he has 100's of molds and were talking 30-60 years and none of them have ever warped. also most of his don't have a lot of stiffener support. and they sit outside to boot. don gave a good post too.
