Projects Re-skin 37 GMC cab
Discussion in 'The Hokey Ass Message Board' started by 37 jimmy, Dec 30, 2020.
  1. 37 jimmy
    37 jimmy
    Any ideas on what I could use to re-skin the back of my 37 GMC cab? Car roof? I can't find any place that will work on it. Everybody wants to do full restoration work. I just had everything acid dipped and epoxy primed.
  2. mcgyver
    mcgyver
    What all do you need? The 37 Chevy cab is the same. They aren't all over the place, but they can still be found.
  3. Budget36
    Budget36
    Post some pics of what you have to work with, folks here might be able to give you a better idea
  4. chev34ute
    chev34ute
    Any car roof can be used as long as it overlaps it.
  5. Romanceofcrime
    Romanceofcrime
    I’m running into a similar problem myself!
  6. Squablow
    Squablow
    With pictures of the damage we could likely offer some good advice.
  7. Post a pic.
    I made a skin from the belt line down for a 39 from new sheet metal. It was easy.
    Hnstray likes this.
  8. Did you consider a good sheet metal shop ? Years ago I had the back of a 1936 Willys pickup cab made. They rolled the sides, and put a flange along the bottom. I let them use my rusted out Willys pickup cab as a sample.
  9. X-cpe
    X-cpe
    Make some templates of the back of the cab and head to the 'pick & pull'.
