Technical Re-using a seal
Discussion in 'The Hokey Ass Message Board' started by alanp561, Jul 14, 2024.
  1. alanp561
    alanp561
    I had the 283 I'm rebuilding just about ****oned up when I realized that the new timing chain cover I had already installed didn't have the timing pointer on it. I dug out the old one and the crankshaft seal on it was toast. I made a small jig to re-locate the pointer and then drilled the two spotwelds out. In order to remove the new cover from the engine, and not wanting to remove the pan, I backed the two front pan bolts out a couple of turns and wedged the front of the pan down just enough to get the rubber pan seal out without tearing it up. Since the engine has never been fired, can I re-use that seal? If so, the only extra expense is going to be the timing cover and water pump gaskets.
    Sharpone likes this.
  2. lothiandon1940
    lothiandon1940
    As much as I hate to say yes, yes, if it isn't boogered up. Don't forget, there are 2 different pan to timing cover seals, thin and thick for SBC. I'm sure you have the correct one.
    alanp561 and Sharpone like this.
  3. lothiandon1940
    lothiandon1940
    Then again..........It's a lot easier to do it right now than if it leaks after install. If you plan to run it on a stand first, that would tell the tale and still be an easy fix.
  4. Absolutely, I wouldn’t think twice about reusing the seal. One think about being a professional mechanic, it gives you the experience to know what is possible. Your engine was never run, the seal was never exposed to oil, the seal was never heated up. I would clean off all of the sealant used in the corners, and put it right back together.
  5. Why would you choose NOT to replace the gaskets? In a rush? If the old one fails will you replace it or just let it leak? If you would replace it then you aren't in that much of a rush? I try to do everything on my cars the BEST that I CAN. If I run out of talent or my skills aren't great, but I do things the best that I can. I will live with the short comings. However if I take a short cut because oF being in a rush or it's to hard, or I'm tired, well that's just a FOOLS mistake and I deserve what I get. Doing the right way means THE RIGHT WAY. Don't settle for GOOD ENOUGH!!
  6. :rolleyes::rolleyes::rolleyes:
    Ben
    Fitty Toomuch and alanp561 like this.
  7. 1971BB427
    1971BB427
    from Oregon
    If it was mine I'd replace any seal that was disturbed. And considering how often those front seals for timing covers to pan can leak, I'd never let that seal be reused. I'd hate to see my brand new engine begin leaking after it was in the car for the cost of new seals, gaskets, and some time.
  8. chicken
    chicken
    from Kansas
    Of course you can still use the seal. It hasn't been damaged at all. Just ***emble like normal with dabs of rtv in the corners and all is well. I might be wrong though...only done it about 50 times in my job. :rolleyes:
  9. squirrel
    I'd worry about the end of the pan gasket.
    lothiandon1940 and Sharpone like this.
  10. jimmy six
    jimmy six
    Back in the early 60’s we changed cams in the same way. Back before RTV for the corners. None of engines were even close to near new. We punPermatex #2 on the corners and on the pan gasket as best we could…new should not be a problem..
  11. garyf
    garyf
    Leaking front seal slings oil everywhere,. usually ruins any rubber components. Belts ,hoses, front suspension bushings, damper rubber and oil is $5. + a quart
  12. Sharpone
    Sharpone
    Permatex #2 best stuff ever, the seal will be fine, if sliding seal over crank twice - of course without nicking or rolling the tension spring out- hurts the seal That seal wasn’t going to last anyway!
    Dan
    lothiandon1940 likes this.
  13. chicken
    chicken
    from Kansas
    Guys-he's talking about the rubber horse shoe shaped seal between the pan and front cover.
  14. alanp561
    alanp561
    Pan gasket hasn't been crushed or displaced. Just enough down pressure on the thin bladed screwdrivers I used for wedges to allow the rubber seal to slide out.
    chicken, lothiandon1940 and Sharpone like this.
  15. Sharpone
    Sharpone
    Dah - Well hells bells, some days I’m so dense I make lead look super lightweight.
    Same thing though, if the seal isn’t damaged I’d reuse it and use the same sealant you used originally
    Dan
    lothiandon1940, chicken and alanp561 like this.
  16. BamaMav
    BamaMav
    from Berry, AL
    I don't see why it wouldn't work. It hasn't been crushed long enough to take a set, hasn't had heat or hot fluid on it. I don't see a problem. They make reusuable pan gaskets, what's the difference? Both are rubber.
  17. fastcar1953
    fastcar1953
    Is it a one piece gasket?
  18. alanp561
    alanp561
    This
    This one
  19. Only thing id worry about is the pan gasket. If cork replace it. If neoprene it's fine
  20. i7083
    i7083
    To paraphrase,
    "I'd use it ".
  21. fastcar1953
    fastcar1953
    All I use any more is one piece pan gaskets.
  22. RodStRace
    RodStRace
    This is going to be a coin flip.
    On one side you will have those that have done it and had luck doing so.
    On the other, you are going to have those that can't stand the risk/reward ratio.
    So, are you lucky and experienced, willing to take a risk?
    Or are you unsure and worried?
    Since you posted here asking, I'd wager you are in the second camp. :)
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    Pull the pan , get a 1 piece pan gasket put a new seal in the timing cover & a new gasket , one & done .
