Read end gearing help needed
Discussion in 'The Hokey Ass Message Board' started by woodhawg, May 3, 2009.
  1. woodhawg
    woodhawg
    Ok, new to all this. Bought a partially finished Model A Roadster with 306 Ford, C4 and 9" Ford rear end. Took a peek inside chunk and it looks like a 2.75/1. Plan to run 29" OD rear tires. Should I plan to change to 4.11 or somthing like that?
    Also output shaft of transmission and input of rear end are not inline. Chunk input is about 3" to starboard of ******. That a problem?
    Thanks for your help.
  2. Glen
    Glen
    If you go to www.randysringandpinion.com there is a calculator to determine what gear ratio you want. Key in tire size, mph, and it will give you RPM.
  3. duste01
    duste01
    Not if the rear end is mounted geometerically square. Its the pinion angle you have to worry about.
  4. 73RR
    73RR
  5. AnimalAin
    AnimalAin
    I ran 3.00 gears with 30 inch tires for a long time in my roadster. It works really well on the highway, and my car is light enough that the around town performance was OK as well. If you don't plan on long-distance running on the highway, 3.50 to 3.90 gears will give more dig in town. 4.11 gears will give a lot of snap in town, but will make the cruise rpm pretty busy (about 4000 rpm at 80).
    By the way, my roadster currently has a 3.90 rear gear, 30 inch tires, and an AOD to get great dig around town and long legs at cruise. A good deal all around.
  6. duste01
    duste01
