Reading sent PM's
Discussion in 'Questions & Suggestions' started by joeycarpunk, Feb 23, 2005.
  1. joeycarpunk
    joeycarpunk
    from MN,USA
    How do I look up messages I Pm'd to other people to read text?
  2. Look on your private messages page. Under the folder controls it says "jump to folder". Click on it and a drop box opens. In it is your sent pm's.
  3. joeycarpunk
    joeycarpunk
    from MN,USA
    That worked to a point, its only showing stuff from last month nothing current. What else am I doing wrong?
    Thanks for the help so far.
  4. joeycarpunk
    joeycarpunk
    from MN,USA
    Bttt, what am I doing wrong?
  5. murph
    murph
    In case you don't have an answer yet...
    First off - when you send a PM, there is a check box that you can select which will save a copy. You can do this for each PM you send, and it will be listed in your "sent PMs".
    Second - there is likely a way to set some environment flag to always save sent PMs, but I haven't figured that out yet.
    -murph
