Technical Real Gassers 101...OK what is this?
Discussion in 'The Hokey Ass Message Board' started by F-ONE, Feb 3, 2022.
  1. Not every g***er had an axle, in fact many of them didn't.
    upload_2022-2-5_6-40-2.png upload_2022-2-5_6-41-14.png upload_2022-2-5_6-42-1.png upload_2022-2-5_6-42-31.png
    upload_2022-2-5_6-44-16.png upload_2022-2-5_6-45-4.png upload_2022-2-5_6-47-0.png upload_2022-2-5_6-58-56.png upload_2022-2-5_7-1-9.png
  2. bobss396
    bobss396
    Any stock car I had was junkyard sponsored... for obvious reasons...
  3. squirrel
    I worked at a junkyard, and they didn't sponsor my racing :(
    bobss396, alanp561 and hrm2k like this.
  4. oldtom69
    oldtom69
    from grandin nd
    The old NHRA stock cl***es also resulted in some cars that while "posible" by the factory options,never really came off the ***embly lines!Most infamous was the Hydra-matic Chevy sedan deliverys.GM put Hydra-matics in pick-up trucks,and sedan delivers COULD be licensed as trucks in some states-guys reading between the lines decided it was "possible" to have a hydra-matic in the p***enger car based sedan delivery.NHRA let it happen even though it took a lot of aftermarket parts[bellhousing,etc] to do it
  5. Ebbsspeed
    Ebbsspeed
    We know what you meant.
  6. RmK57
    RmK57
    Could be Fontana wasn't an NHRA sanctioned track. Different rules apply to stock cl*** racing depending on which organization you run in.
  7. Marty Strode
    Marty Strode
    Why would you need an aftermarket bellhousing, just use the setup from a pickup truck.
    Fordors, alanp561 and olscrounger like this.
  8. Marty Strode
    Marty Strode
    L Stock was the bottom cl*** until 62 or 63, then NHRA went to N. My 64 rulebook, automatic cl***es only went through I/S, and I remember it required a minimum of 3 automatics to have a separate cl***. At least that was the rule at McMinnville, Or.
    Bandit Billy, lippy, Mark Yac and 3 others like this.
  9. So this car would not have come about until the '70s? Not saying this to be mean I understand your logic totally. I just am not sure that it is definative.
    my reference to '64 was along the lines of a rule change that happened in '65 that changed "g***ers" from street vehicles to got raced to a full on compe***ion cl***. Prior to the rule change Gas Cl*** was basically Stock cl*** with a few tweeks, engine set back for example or power adders.
    My dad and his cronies wore popadours by the way. I did wear a crew cut myself but that was because grooming was not my thing and a crew cut was easier.
    LOST ANGEL, loudbang, F-ONE and 2 others like this.
  10. It was advertised HP to weight. One side-effect of that was due to the allowable engine mods in stock and super stock, some of the factory hipo motors weren't compe***ive as the lower HP versions could be tuned to the same power levels as the hi-po without the penalty of the higher rating.
    vtx1800 and loudbang like this.
  11. RICK R 44
    RICK R 44
    There is a feature article on this car and owner, Carl Swift in September 2017 Hot Rod Deluxe
  12. swade41
    swade41
    from Buffalo,NY
    This is from a November 1954 magazine, rules were always changing
    LOST ANGEL and loudbang like this.
  13. oldtom69
    oldtom69
    from grandin nd
    GM only put the Hydro-matic behind the Pontiac and Buick based V-8 they used in pick-ups at that time.Plus the small block pick-up bellhousing had slightly different side motor mounts than the 55-57 p***enger car bellhousing Edit-some books show the Hydra-matic behind the 265,so maybe it was just very rare bellhousing?
  14. oldtom69
    oldtom69
    from grandin nd
    Kinda like the Thunderbolt that came with an automatic-special bellhousing to put the Lincoln trans behind the FE engine
  15. Correct.. You could run an automatic in those lower cl***es but same cl*** and record as a stick...i.e, 303 Olds could be found either way.
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    G***ers without straight axles?.... That will chap some a$$es...
    The quest for speed and traction led to many experimentation things over the years, some worked, some didnt...
    The move to straight axles I think was a bit to try to reduce front end weight, and we all know some of the early IFS junk couldn't handle being cycled all the way up to down in split seconds, but main issue I think was getting the steering right, IFS has a major heel when it comes to compression and rebound and how the tires toe in and out. I think some folks figured they could pick up some stability and drivability with straight axle and I'm sure they did.
    None the less.. still cool by todays standards, and part of the history of racing etc.
    55 Ford Gasser likes this.
  17. Stan Back
    Stan Back
    Well, I hate to ruin the conversation, but I believe Fontana ran AHRA rules back then. So all this NHRA examples don't fit.
    We found a huge difference in cl***es between the two. Our (slow) C/R (C cl*** gas Roadster) would move us up to A in NHRA rules. We also ran for free at Fontana and p***ed up the WinterNationals at Pomona because they wanted a $25 entry fee.
    Tman likes this.
  18. 1320 Fan
    1320 Fan
    If you were at Fontana or Irwindale in the late 60's that orange ford and its owner Carl Swift were usually around the pay window at the end of the day.
    Mark Yac and loudbang like this.
  19. wvenfield
    wvenfield
    No it won't. It's been discussed here many times. Picture after picture has been posted.
    loudbang, Tman and stubbsrodandcustom like this.
  20. Mimilan
    Mimilan
    My F.I.L 's car was sponsored by his children's inheritance.
  21. seb fontana
    seb fontana
    from ct
  22. Bandit Billy
    Bandit Billy
    Drag racing will make you moderately wealthy...if you start out a millionaire. Thanks dad!
    loudbang and seb fontana like this.
