Technical Real News - Fake rivets
Discussion in 'The Hokey Ass Message Board' started by billfunk29, Mar 4, 2023.
  1. billfunk29
    billfunk29
    from Minnesota
    This was inspired by blind aircraft fasteners. But they come in limited sizes. So make your own. Trick is to weld a nut on the end of a long set screw. I use 18-8 stainless for the weldability. These are not strong. Don't use this trick on suspension bolts or any bolt that needs to be strong. Get the aircraft ones if you are doing that.
    Pretty simple. Weld the nut on the end opposite the hex drive hole. Then grind the dome. I use a drill and grinder. rivet2.jpg rivet4.jpg rivet5.jpg
    Bcap55, bobss396, winr and 16 others like this.
  2. "Sometimes you feel like a nut...... Sometimes you don't."
  3. hotrodA
    hotrodA
    Genius! Thanks!
  4. A Boner
    A Boner
    Refreshing…in my world, usually it’s fake news and real rivets. Cool idea, thanks!
    Budget36 likes this.
  5. fordf1trucknut
    fordf1trucknut
    Recently I discovered that set screws do NOT like tension like a regular bolt does. I used set screws that I got new from a reputable fastener supplier with structural heavy nuts to bolt an adapter to the hubs on my vintage racecar project...... only to find that 3 of the the set screws busted!! It shot 3 nuts with half the set screw inside about 3 feet from where they broke. This was in a project so it was not moved or stressed in any way other than torquing the nuts!!!! So after finding this I cut grade 8 all thread and replaced them all for safety. I was very surprised by this... so just an FYI.
    chryslerfan55, 2Blue2 and Beanscoot like this.
  6. millersgarage
    millersgarage
    man, I just use ribbed neck carriage bolts.
    easy
    williebill and bobss396 like this.
  7. manyolcars
    manyolcars
    I've been making rivets out of bolts for 40 years
  8. chopolds
    chopolds
    from howell, nj
    You can buy rivets with 10-32 threaded shafts. Look for places that make lockers. Cheap, too.
    AccurateMike likes this.
  9. Doublepumper
    Doublepumper
    from WA-OR, USA
    62rebel and FishFry like this.
  10. Ebbsspeed
    Ebbsspeed
    I've been making them on the lathe since Moby **** was a minnow.
