Really REALLY low profile air cleaners
Discussion in 'The Hokey Ass Message Board' started by ANDEREGG TRIBUTE, Jul 22, 2011.
  1. hemifalcon
    hemifalcon
    I think I'll be getting one of these for my '61.. Just cuz it looks right..
  2. Deuces
    Deuces
    I have that lower base including the upper piece for an early Z/28 or LT-1 motor... The upper lid has the AC-Delco ink stamp underneath..
  3. hemifalcon
    hemifalcon
    If one of you guys want to let your Corvette unit loose, let me know.. I'd like to try one of these out..
    -John
    jparello@yahoo.com
  4. i see youve already got the corvette one on the way, but heres one i made for an off topic car that was super low profile, i took a regular dropped base, and hammered the **** out of it to clear the throttle body and cut about .5 inches off the bottom lip. then made the top from scratch. we milled the intake down too and it just barely made it without touching the hood.
  5. Going to be hard to get the optimum 3" between the air horn and air cleaner lid with that intake....
    What about a stock intake with the Carter AFB?
  6. check with the people that make kits to put small blocks in pintos, vegas, and MGs and such.. stupid cramped spaces there...
  7. 48 Chubby
    48 Chubby
    Looks to me that you could gain about two inches or more with a early Corvette intake. That "Hi Riser" intake you have on now ain't what Anderegg used, in fact I don't remember seeing those before the late '60's.
  8. indyjps
    indyjps
    intake looks like a victor to me from what I can see. check out edelbrock torquer or performer if youre not already running one.
    Airrade tapered air filter / base. not traditional but may match curve of hood. http://www.summitracing.com/search/.../Base-Style/Dropped/Brand/Airaid/?Ns=Rank|Asc
    10 inch drop base Proform air cleaner. http://www.summitracing.com/search/.../Air-Cleaner-Size/10-in-diameter/?Ns=Rank|Asc
    repo drop base tri power corvette air cleaner http://cgi.ebay.com/ebaymotors/Tria...r_Truck_Parts_Accessories&hash=item45fb70f5a5
  9. 35touring
    35touring
    from Kentucky
  10. Bruce Lancaster
    Bruce Lancaster
    Coupla things...GM made in the ,80's, roughly, a Q-jet-Holley type lid with a hose fitting to connect a cleaner elsewhere. I think maybe early turbo Buick?? I have one somewhere. Runnit to firewall, air cleaner tucked behind dash?
    The low drop is not a problem area. You can get way deep OEM bases, cut off the edge, and add a shiny top to get wnough filter area, BUT be aware that a low lid on an aircleaner can disrupt venting and intake flow and cause lots of mixture problems. Use every spec of al***ude you have there, and since it will be low no matter what, road test with and without the cleaner on to see if there is a detectable problem,
  11. 39 All Ford
    39 All Ford
    from Benton AR
    You can get a low enough air cleaner "off the shelf", but in my experience trying to get as low as I could with an off the shelf drop cleaner, the limiting factor was the choke ***y. on the carb.
    I was under the hood and operational with a Barry Grant no choke carb, but I ran out of room with any carb with a choke.
  12. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Well I think it may actually work. I dont want to butcher up the original vette bottom (as it is not made for a Holley). So Im going to fab me up one and in the process off set the whole air cleaner forward 1/2 inch in case I stick with the HEI.
    Oh, and this is with an Edelbrock Performer intake as it is a full 3/4 inch lower than the single plane I had milled.
    Tim likes this.
  13. Deuces
    Deuces
    a couple of these would look very cool on a 6.71 blower... :eek::D
  14. Cerberus
    Cerberus
    This was at the NAPA Auto Parts show 10 days ago.
  15. poboyross
    poboyross
    from West TN
    Who makes this, what's their website, and how many duckets??!?!? :eek:
  16. THE_DUDE
    THE_DUDE
    I use a drop base bottom and a 1 1/2 inch filter darn near flat
  17. 3rd Gen Hot Rodder
    3rd Gen Hot Rodder
    from Indiana
    I know it is a little late in the game now, but if you need another suggestion, when my late father faced a similar situation on our family's Ardun powered 48 Mercury, he went a little unconventional with a Harley air cleaner. Works great and looks pretty good too if I do say so myself...
    Tim likes this.
  18. 41woodie
    41woodie
    Several cars ago I had a little '24 T with a Volvo engine with SU carbs mounted on the side. It was extremely close to the hood side panel but I finally solved the problem by going to a small engine repair shop and looking through their supply of lawnmower/small engine filter elements. When I found a shape that I thought would work I fabbed up a sheet metal frame for it and voila! air filter. Maybe not the prettiest solution but it worked.
  19. 41woodie
    41woodie
    Ok my lawnmower filter wasn't pretty but it was better than this thing
  20. coolbreeze1340
    coolbreeze1340
    from Indiana
    Modifiy the air cleaners used for corvairs. They are mad to drop down to the side into in open area. Not sure how much clearance it will take but it might work and the ones on a early 'vair would look almost period! LOL
  21. coolbreeze1340
    coolbreeze1340
    from Indiana
    Anybody found out about the dual side draft set-up pictured? I'm thinking two sets on a 2x4 intake would look killer!
  22. R Frederick
    R Frederick
    from illinois
    You put an air cleaner on your master cylinder? lol
  23. 41woodie
    41woodie
    Not absolutely sure about them being Webers or Dellortos. On a previous SBC powered car I ran a very similar looking setup on top of a B&M Blower. They were Dellortos and basically made a very tuneable four barrel.
    I seem to remember that it came from Street & Performance in Mena, Arkansas but that's not for certain. I know I had S&P make me a set of aluminum air cleaners for it. They were about 10-12" by 6-7 inch rectangles and looked pretty decent. I have a picture of the engine around here somewhere if it needs to be seen.
  24. Aquaroscoe
    Aquaroscoe
  25. poboyross
    poboyross
    from West TN
  26. R Frederick
    R Frederick
    from illinois
    There's two sets on Egay right now for $1,500. Use one and sell the other set. They are actually shorter than shown. Looks like the adapters say B&M on them.
    I'd post a link, but I don't think I'm supposed to.
  27. R Frederick
    R Frederick
    from illinois
    Silverfox Racing likes this.
