Technical Reaming of door pin hinges ?
Discussion in 'The Hokey Ass Message Board' started by Gurt74, Sep 24, 2018.
  1. Gurt74
    Gurt74
    So, I'm trying to sort the hinges out on my 35 ford coupe. What a b***h of a job. Puller s, heat,hammer and punches, drills combined with plenty of colourful language got them out ! I've bought some oversize hinges to sort out the slack. Now do I redrill the holes or ream them out?
    Sent from my SM-A520F using The H.A.M.B. mobile app
  2. Gurt74
    Gurt74
  3. Sporty45
    Sporty45
    Reaming will be more accurate, a drill bit can walk on you where a reamer will follow the original hole.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Agreed.
    Reamers cut more accurately. Important when installing new oversized pins.
    Sporty45 likes this.
  5. TagMan
    TagMan
    Absolutely - make or buy oversize pins unless the hinges are a mess. If the hinges NEED to be opened up due to being out of round, use the proper sized reamer. A drill bit does NOT drill a perfectly round hole.
  6. J. A. Miller
    J. A. Miller
    from Central NY
    You really don't know how to swear until you've removed the pins from early Ford hinges. And I had military training in swearing!
  7. patterg2003
    patterg2003
