Technical Rear axle 1932
Discussion in 'Traditional Hot Rods' started by 3wmike, Dec 8, 2021.
  1. 3wmike
    3wmike
    Are there any differences between the earlier and later rear axle 1932,
    has the 1933-1934 axle any advantages against 1932 axles
    Thanks Mike
  2. continentaljohn
    continentaljohn
    Mike you have late and early 32 rearends ,early are like model a fords and have a round flange mounting the torque tube to banjo The later 32 axle is like a 33-34 rearend and scalloped at the mounting.
    LOU WELLS and Harms Way like this.
  3. alchemy
    alchemy
    The late 32 axle is the same as 33-34 axles, except for the length of the driveshaft and torquetube. No strength or design changes.
    Harms Way likes this.
  4. Early 32 has less bearing support cast in.Later got beefed up.
  5. hemihotrod66
    hemihotrod66
    Early 32 rear ends are like A models sometime mid year they changed to having a straddled mounted pinion support bearing.... Which continued thru the banjo rear end production...I believe the later Ford dropout third members with straddle mounted pinions used the same bearing in the later years,,,
  6. clem
    clem
    Just curious,
    I was told that the ‘32 had parallel brackets for mounting the wishbones, and ‘33 - ‘34 had angled brackets, or did they change the late ‘32 to angled brackets also ? - (maybe a ford barn type questions) Anyone know ?
    Thanks !
  7. alchemy
    alchemy
    Early 32 had parallel, later 32 turned to angled when they added the pinion support. None of the early and late parts interchange as far as I know.
    clem likes this.
  8. Duke
    Duke
    Late 1932, cleaning it up before it is taken apart for a rebuild. 4C591C2F-CD71-4EAB-8AAD-C8717982DA8E.jpeg
  9. 3wmike
    3wmike
    Thank you guys, much information on this page
    clem likes this.
