Rear axle autopsy questions
Discussion in 'The Hokey Ass Message Board' started by Lucky77, Feb 2, 2009.
  1. Lucky77
    Lucky77
    Sorry if this is a little too new for the HAMB but the subject at hand is still relevant. LuckysGal has a 2000 Chevy pickup and she was turning around in a driveway and heard a clunk in the rear end. Then she reversed it and heard another loud noise. After that she put it in 4X4 high and limped it home. It wouldn't move in two wheel drive mode. Today I finally got a chance to look at it and this is what I found.
    The spider gear on the passenger side was hammered flat. I thought maybe the axle had snapped and this gear stayed stationary as the others beat it into submission. I jacked up the rearend and had her try and spin the RR wheel and it wouldn't budge so maybe the axle isn't broken or everything heated up and welded it's self together. However this is as far as I'm tearing into it, do you guys have any thoughts on what might have happened?
  2. 34toddster
    34toddster
    from Missouri
    Does she have a teenage Son? Cause I made a bunch of rear ends look like that when I was a youngster!
  3. Lucky77
    Lucky77
    She better not, she's only 29 and hasn't mentioned any to me in the last two and a half years:eek:
  4. With the amount of shrapnel that is going to be in and through all of the bearings and gear teeth I think you might be better off with a different rear end. Just make sure its the same ratio.....
  5. Brickster
    Brickster
    The spider and axle gears are notoriously bad in those diffs. You can get an internal kit for them but most of our customers choose to upgrade to a posi unit. I'll need to completely dissassemble the diff to remove all the shed metal. Metal will absolutly get caught between the two pinion bearings so please don't fix it without pulling the pinion and fishing out all the stuff in the recess between those bearings as well as cleaning the tubes.
    Brick
  6. 302GMC
    302GMC
    from Idaho
    This happens when one wheel is spinning in the snow and finally hooks up with the pavement.
  7. Ramblur
    Ramblur
    Find her another rear axle and build her a trophy outta whats left of this one
    for valentines day....
  8. zbuickman
    zbuickman
    when GM went to the 8.625 rear the also went to cast spiders(instead of bar stock spiders).... THEY ARE SHIT!!!!!!!!!!!!!!!! Upgrade to something aftermarket. or with spcial bearings you could float an older 8.5 in there. which would last MUCH longer...... Again if you put GM parts back in there IT WILL BREAK AGAIN..... Im a GM guy too kinda sad aint it:(
  9. Brad54
    Brad54
    from Atl Ga
    In the second picture, on the driver's side spider, up where the top and side spiders meet, is there a chunk of metal wedged in there? Looks like it in the photo.
    -Brad
  10. LuckyGal
    LuckyGal
    from Saginaw
    So all those donuts I did, I'm assuming, didn't help. Thanks for your help guys... I think I'll be looking in a junk yard for a whole axle assembly. Then, bye-bye Chevy!
  11. BigMikeC
    BigMikeC
    9 inch Ford... Fixed
