Technical Rear axle for 53' 3100
Discussion in 'Traditional Hot Rods' started by frenchyseb, Sep 20, 2017.
  1. frenchyseb
    frenchyseb
    Hi, I 'd like to install a new rear axle on my chevy, so I have find one from a 79 firebird and one from a c1500 between 80' and 90'
    According to you which one is the best and the easier to install?
    Thanks
  2. if memory serves, you want between 58"- 62'' wide.
    BigMike
  3. some things to consider....what are the gear ratio of both rear ends? how will those gear ratio's work with your engine/transmission choice? how wide are both of them wheel mounting surface to WMS? how wide is the stock rear end? what size tires/wheels do you plan on running?
  4. frenchyseb
    frenchyseb
    my actual axle is 58" wide, i just want to replace it to put the truck on air because mine is in one piece without "articulation" if you know what i mean
