Rear Axle help..
Discussion in 'The Hokey Ass Message Board' started by stubbsrodandcustom, Jan 23, 2013.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Ok so Ive been working on my pops 58 ford fairlane... well someone over the years I think swapped out the 9" for a early model like 50 or 51 axle... So here is my delima... It has a bent axle shaft and is hard to find parts for and the diff is very worn... So It has a 57.25" Hub face dimension... Im wanting to get something narrower than this down to about 55.5 or 56" cause I have to pull the shocks to get the wheels off now and a inch or so would help this out alot...
    Suggestions?
    Orig thoughts is get a 9" narrowed down for this...
  2. 31Apickup
    31Apickup
    I beleive the narrowest factory 9" is the 57-58 wagon at 57 inches. Another option is to use a Maverick 8" they are 56".
  3. Mr48chev
    The Maverick rear would work but is probably harder to find.
  4. hrm2k
    hrm2k
    enjoy
    Ford Outside
    Width Year Model
    57.25 1957-1959 Ford, Ranchero, Station Wagon
    57.25 1965-1966 Mustang
    58.00 1966-1977 Bronco
    58.00 1964-1965 Falcon
    58.00 1977-1981 Granada/Versailles
    58.50 1977-1981 Versailles
    60.00 1958-1960 Edsel
    61.00 1964-1971 Ford Full Size
    61.00 1949-1951 Mercury
    61.25 1957-1972 Ford F-100 Pickup
    61.25 1960-1964 Ford Full Size
    61.25 1971-1973 Mustang
    61.25 1967-1973 Torino, Ranchero, Fairlane
    63.00 1970-1979 Ranchero & Torino
    63.00 1972-1979 Ford Full Size & Intermediate
    63.50 1967 Fairlane
    65.25 1973-1986 Ford F-150 Pickup
    65.25 1978-1986 Bronco
    65.25 1973-1986 Ford Van 3/4 Ton
    68.00 1972 Ford Van 3/4 Ton
    69.25 1977-1986 Ford E-150 Van
    Chevy Outside
    Width Year Model
    57.75 1962-1964 Chevy II/Nova
    57.75 1965-1967 Chevy II/Nova
    58.00 1978-1988 Chevy Malibu, Monte Carlo
    59.50 1968-1982 Corvette
    60.00 1955-1964 Chevy Car
    60.00 1967-1969 Camaro
    60.25 1968-1979 Chevy II/Nova
    60.50 1984-1995 Corvette
    60.50 1964-1967 Chevelle
    62.00 1955-1959 Chevy Pickup
    62.50 1968-1972 Chevelle
    62.50 1970-1981 Camaro/Firebird
    Mopar Outside
    Width Year Model
    55.60 1960-1976 7 1/4 A-body
    55.60 1973-1976 8 1/4 A-body
    55.60 1966-1972 8 3/4 A-body
    55.60 All 8 3/4 A-body
    56.00 1932-1934 All Mopars
    57.40 1963-1972 7 1/4 A-body
    58.54 All 8 1/4 F-body
    58.54 All 8 1/4 M-body
    58.54 All 8 1/4 J-body
    59.00 1935-1936 All Mopars
    59.14 1966-1970 9 3/4 B-body
    59.20 1962-1970 8 3/4 B-body
    60.00 1937-1948 All Mopars
    60.70 All 8 3/4 E-body
    60.70 All 9 3/4 E-body
    62.00 All 8 1/4 B-body
    62.00 1971-1974 8 3/4 B-body
    62.00 All 9 1/4 B-body
    63.40 All 8 1/4 C-body
    63.40 1971-1974 8 3/4 B-body S.W.
    63.40 All 9 1/4 C-body
  5. any pictures of the current rear end?
  6. aaggie
    aaggie
    The 9" rear in 57-59 Fords was 57.25" and small bearing. I don't know why you would have to remove the shocks to change a tire. Are your rims made with a deep backspace or something? Were the shock mounts moved for some reason?
  7. Mr48chev
    Looking at chart HRM2K posted the Mopar A body axle would get you right where you wanted to be but may again be hard to find now. Again it it may be a lot less expensive than buying and modifying a nine inch though.
    I'm saving that chart for sure.
  8. Deuce Roadster
    Deuce Roadster
    The 57/59 Ford rear ends also come in the large axle bearing style.
    I have a 57 Ford rear end with the large bearing. You generally find the large bearing models under station wagons, Rancheros and convertibles but I have found them under regualar sedans also. :)
  9. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    here are some pics...
    If you can identify it you win the Hamber of the year in my book... :D
  10. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
  11. landseaandair
    landseaandair
    from phoenix
    I think you already ID'd it with your first guess, 1949-56 Ford car.
  12. 60srailjob
    60srailjob
    from nowhere
    thanks for the chart...
  13. crowerglide
    crowerglide
    from Tyler, TX
    Yes, thanks very much for the chart. Now, if I just knew what's a Chrysler A-body, B-body.........:D
  14. Von MoPar
    Von MoPar
    from Australia
    great info on the measurements....thanks
  15. hrm2k
    hrm2k
    the chart came from a thread on here from about 6 years ago.........I kept it just incase
