Technical Rear axle not perpendicular to the frame
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Jul 19, 2021.
  1. Almostdone
    Almostdone
    I think with the width of rear end you have the spacers are going to be the fix. You’ve already squared things up based on this thread, but wow - not much space between tires and body. Mine has a lot more space, but that’s not saying it’s the only way to do it. If I lowered the coil over adjustment I could be in the same situation you are.
    That’s a great looking car - it should be a lot of fun.
    John
  2. Dino 64
    Dino 64
    from Virginia
    Thanks, got the spacers today but the car is getting a snap on top, at the upholsterer for now.
  3. Spacers and or reversed rims, stiff shocks and proceed.
    loudbang, lothiandon1940 and Dino 64 like this.
  4. Dino 64
    Dino 64
    from Virginia
    Got the spacers today, I’ll post the differences
    Thanks
  5. blvdbill
    blvdbill
    Just loosen the bars un hook them , center the rear end
    And adjust them , very simple.
    indyjps, Dino 64 and loudbang like this.
  6. Dino 64
    Dino 64
    from Virginia
  7. Almostdone
    Almostdone
    So you’re done?
    John
  8. indyjps
    indyjps
    Looks like you got it figured out.
    Its rubbing on the front of the wheel arch so the axle needs to move rearward....lengthen all your bars to push the axle rearward.
    If one of the tires is still closer to the body, and your bars are equal length.... loosen the body bolts and shove the body over to center it up.
  9. Dino 64
    Dino 64
    from Virginia
    I’m gonna try the spacers to see how the wheels are sitting. Had a friend drive behind me to make sure the car isn’t dog walking. I’m sure it’s not perfect but it’s not a dragster. It’s good for a driver.
    Thanks for all the responses and suggestions ;):)
  10. milwscruffy
    milwscruffy
    Did you ever check wheelbase from side to side afterwards ?
    loudbang and lothiandon1940 like this.
  11. Dino 64
    Dino 64
    from Virginia
    Yes ! Not perfect but very close
  12. Dino 64
    Dino 64
    from Virginia
    6FBE730C-D4CF-491A-A4A8-9AB265D8ED03.jpeg 5D7082E2-A6B1-4AE1-978F-99F4E208D90E.jpeg 01F9D549-3E2A-4488-8B22-FE5361368812.jpeg Just to wrap this up.. before spacer and after. 1/4” spacer CF22F48C-5CA1-4DB4-A978-02C7714AA922.jpeg
  13. milwscruffy
    milwscruffy
    Problem solved !
  14. Dino 64
    Dino 64
    from Virginia
    Think they look too far apart ??
  15. lothiandon1940
    lothiandon1940
    ...........Looks perfect to me.
    loudbang and milwscruffy like this.
  16. Dino 64
    Dino 64
    from Virginia
    Thanks Don :)
  17. loudbang
    Now you can have fun DRIVING it and not fixing it. :)
    Dino 64 likes this.
  18. Almostdone
    Almostdone
    Looks good now. Have fun with it!
    John
    loudbang and Dino 64 like this.
  19. Dino 64
    Dino 64
    from Virginia
    Thanks guys, went for a twilight cruise last night, just plain fun ! :D:D
    milwscruffy and loudbang like this.
  20. RodStRace
    RodStRace
    Yeah! Drive it, work the bugs out and then touch up the spots!
    Are the brakes, suspension, steering all good? Exhaust sound good without any cruising drone? Interior comfortable and everything 'in it's place'? No leaks or rattles? Everything still tight after 500 miles? Engine at it's happy place when cruising? Fires off easily when heat soaked? Get all that right then worry about a little spot on the body.
