Technical Rear Axle Seal?
Discussion in 'Traditional Hot Rods' started by Pappys31, Sep 4, 2022.
  1. Pappys31
    Pappys31
    So I pulled the rear drums from the axle and am wondering if I am missing some sort of rear axle seal.
    Picture attached. Any help or guidance would be appreciated.
    Thanks and have a great Holiday!
  2. Inside the axle bell, there is a seal. You have to remove your axle bells to remove and install a new seal. It does require a special tool to do so. The is a simple adapter that threads onto a piece of pipe. The seal is serviced from the inside of the axle bell. Both the tool and seal are available.
    https://www.macsautoparts.com/1932-1948-ford-v8-inner-rear-axle-drive-shaft-seal-32-26684-1.html
    https://www.macsautoparts.com/1928-...er-rear-axle-drive-shaft-seal-28-26684-1.html
    Although Mac's list them as being different for Model A vs. V8 cars, some suppliers list them as the same seal.
    https://www.ebay.com/itm/3919896695...Lr42wl-TtC&var=&widget_ver=artemi***edia=COPY
    You will need about 4 feet of 1/2 inch pipe. The same seal is in your torque tube for the driveshaft as well. I will also add, this is not easy and requires most of the axle ***embly to be removed from the car and completely torn apart. If it ain't broke, don't fix it.
    Nailhead A-V8 and leon bee like this.
  3. Looks like your also missing the grease baffles as well. Not a big deal, but missing they are.
    ottoman likes this.
  4. Mac VP
    Mac VP
    There are oil seals inside the axle housings (B-4245) and there are grease seals in the hubs (B-1175 or 78-1175 depending on the particular vehicle year). As mentioned, the rectangular grease baffles are missing. They do help keep grease off the brake components should the grease seals fall. We stock all of this too.
    Haven Hills Auto Club likes this.
  5. solidaxle
    solidaxle
    from Upstate,NY
    In addition to the grease housing missing, the brake cylinder is in the wrong location. There's a right and a left. The larger part of the housing faces towards the front.
  6. solidaxle
    solidaxle
    from Upstate,NY
    Looks like your e-brake cable is missing the clip that holds the spring back from sliding into the tubing also.
  7. From the picture it appears your brake shoes may be incorrect as well. One shoe lining should be shorter than the other. I always forget which one. Some help I am.
  8. solidaxle
    solidaxle
    from Upstate,NY
    Longer shoe goes to the front as well.
  9. BJR
    BJR
    There is also a grease seal that goes on the drum.
  10. solidaxle
    solidaxle
    from Upstate,NY
  11. 19Fordy
    19Fordy
    When you reinstall the wheel cylinders correctly , also
    install the correct brake hardware that secures the E-brake arm, etc.
    1940 Ford looks like this. First photo is P***. side. 2nd photo is Driver side.
    Are those the correct backing plate bolts?
  12. Pappys31
    Pappys31
    Thank you for the replies everyone. I will get all the right parts and work on the repairs.
  13. solidaxle
    solidaxle
    from Upstate,NY
    It probably doesn't need to be said. You better inspect the front brakes also.
    Haven Hills Auto Club and NoelC like this.
