Rear axle suggestions 40 Ford
Discussion in 'The Hokey Ass Message Board' started by 40 Flier, Jul 15, 2008.
  1. 40 Flier
    40 Flier
    from Michigan
    I've got a Blazer 2WD disc brake rear end which is too narrow for wheel back spacing over 3 1/2" Like to keep the 4 3/4 lug pattern and 7"+ width wheels. I have an adjustable proportioning valve so I could give up the discs. What are you running?
    Oh yeah, 355 warmed up/350; 700R4 as soon as I get the frame patch for the pan bulge installed
    Thanks
    40F
  2. treb11
    treb11
    70 - 74 nova (what I'm using), late explorer, 67-69 camaro / firebird
  3. 40 Flier
    40 Flier
    from Michigan
    Is the Nova an 8.2 or 8.5?
  4. Henry Floored
    Henry Floored
    That there is one of the finest Fords ever made. Why not run Ford parts in her?
  5. 40 Flier
    40 Flier
    from Michigan
    I agree; looked for a lot of years for a 40. It already "goes down the road" just not the way I want and I'm burning the lights to get back out there. It came with the Chevy driveline and I'm frustrated with the lack of backspacing on this width rear end.
  6. 34hemipu
    34hemipu
    I ran S10 rear in a 35 , had 8" steelys with 2 " backspace and fit perfect . Same frame as a 40 . Pretty deep dish maybe thats not the look your after.
    Mike
  7. AnimalAin
    AnimalAin
    Early Mustang or late 50s Ford p***enger car rears are about the right width. The one under my '40 coupe (59 Ford rear) is (I think, it's been some years) about 57 1/2 wide, mounting face to mounting face. I run zero offset wheels, and it is just about right.
  8. lowkroozer
    lowkroozer
    ford granada or lincoln versaille 8inch and ch***is engineering kit your in business!
  9. rstanberry
    rstanberry
    from terrell tx
    9" from a 70's pickup, narrowed 4" to center the pinion.
  10. treb11
    treb11
    late nova is 8.5
  11. seldom scene
    seldom scene
    I'm running an 8" ford out of a '72 comet, hiway gears, works great, good gas mileage, but I'm no drag racer. Oh yeah ch***is engineering parralel springs.
  12. HotRodGirl40
    HotRodGirl40
    Dad's '40 has a 57-63 F-100 rear axle, but if he were to built it now he would use Explorer...
  13. 40Standard
    40Standard
    from Indy
    57 chev rear end
  14. 296 V8
    296 V8
    from Nor~Cal
    What the hell is a "3 3/4 lug pattern " :confused:
  15. Flat Ernie
    Flat Ernie
    Tech Editor
    Early Bronco (66-73) 9" - near bolt in, right width, right bolt pattern (5 on 5.5"), unlimited gear choices
    Also 8" out of Granada/Monarch - 5 on 4.5" bolt pattern
  16. 40bcool
    40bcool
    from Tulsa,Ok
    I have been running a 66-68 Mavrick 8" on Ch***is Engineering rear spring kit. I have had this setup for 24 years. You use the stock spring pads,you just bolt it on.I am running 8" rear wheels with a 3 3/4" back spacing. the gear is 278. This rear end is a V-8 Mavrick 5 bolt rear end. No cutting,get axles's,bearings anywhere. It works for me.
    40BCOOL
  17. flatjack
    flatjack
    I've got to second the 9" Bronco. Have had one in my 39 for years with a Ch***is Engineering spring kit. Fits perfect.
  18. I am running a 9" Ford rear with 5 on 5 1/2" bolt pattern. Car is getting the interior done at the moment.
    Johnnie.
